Question / Help Audio Echo/ Delay problem
apexdrew
Hi, I've been having this problem of Audio Echo and delay. At first I thought it was my microphone but I tried other microphones but the problem is still there :c ...please help? here is the Log
Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: AMD A6-3620 APU with Radeon(tm) HD Graphics
CPU Speed: 2196MHz
Physical Memory:  4095MB Total, 3343MB Free
stepping id: 0, model 1, family 15, type 0, extmodel 8, extfamily 1, HTT 1, logical cores 4, total cores 4
monitor 1: pos={0, 0}, size={1440, 900}
Aero is Enabled
Adapter 1
  Video Adapter: AMD Radeon HD 6530D Graphics
  Video Adapter Dedicated Video Memory: 524075008
  Video Adapter Shared System Memory: 2672078848
  Base resolution: 1440x900
  Output resolution: 1440x900
Loading up D3D10...
Playback device Default
Using desktop audio input: Speakers (Realtek High Definition Audio)
Using auxilary audio input: Microphone (Realtek High Definition Audio)
Audio Encoding: AAC
    bitrate: 128
x264: using cpu capabilities: MMX2 SSE2Fast FastShuffle SSEMisalign LZCNT
x264: profile High, level 4.0
Video Encoding: x264
    fps: 30
    width: 1440, height: 900
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 1000
    buffer size: 1000
    quality: 8
Total frames rendered: 13695, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:55    Avg QP: 8.05  size:   341
x264: frame P:3441  Avg QP:11.65  size:    51
x264: frame B:10161 Avg QP:14.67  size:    48
x264: consecutive B-frames:  0.8%  0.0%  0.0% 99.2%
x264: mb I  I16..4: 100.0%  0.0%  0.0%
x264: mb P  I16..4:  0.0%  0.0%  0.0%  P16..4:  0.0%  0.0%  0.0%  0.0%  0.0%    skip:100.0%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.0%  0.0%  0.0%  direct: 0.0%  skip:100.0%
x264: 8x8 transform intra:0.0%
x264: coded y,uvDC,uvAC intra: 0.0% 0.0% 0.0% inter: 0.0% 0.0% 0.0%
x264: i16 v,h,dc,p: 98%  0%  2%  0%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu:  0%  0% 100%  0%  0%  0%  0%  0%  0%
x264: i8c dc,h,v,p: 100%  0%  0%  0%
x264: Weighted P-Frames: Y:0.0% UV:0.0%
x264: kb/s:11.91
apexdrew
I will get the video up soon youtube is not uploading correctly for me at the moment but the problem has stopped for now. but I will still put the video up for future reference.
j0hanSE
You don't listen to your stream at the same time as you stream do you?
If you do, it first gonna pick up the sounds from your soundcard, and when you listen to your stream at the same time, it'll gonna take that sound aswell.
// J
