EDGAR_SEC
Hey guys,
So I noticed that whenever I have a capture device/source, right click on it, and select "Output audio to desktop," there is always about a 500ms delay before any audio is output to the desktop.
The issue is present no matter what I set the desktop audio device to and even shows up in a local recording. If I set the capture device/source to "Output audio to stream only," the audio is spot-on. Any ideas on how to fix this on a per source basis?
If not, is there a way to set an offset when using "Output audio to desktop" the same way we can with "Output audio to stream only?"
Both devices are PCIe internal cards (Datapath VisionDVI-DL and Micomsoft card)
Thanks
Log attached. You might notice in the log that I'm using a virtual audio device as "Desktop audio," but this issue is persistent even if I switch the "Desktop audio device" to the analog output onboard Realtek with speakers attached.
Thanks
01:15:59: Failed to initialize plugin plugins/CLRBrowserSourcePlugin.dll
01:16:00: Failed to load plugin plugins/CLRHost.Interop.dll, 126
01:16:00: CLR host plugin strings not found, dynamically loading 4 strings
01:16:00: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
01:16:00: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
01:16:00: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
01:16:00: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
01:16:00: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
01:16:00: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
01:16:01: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
01:16:01: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRHostPlugin
01:16:01: CLRHost::LoadPlugins() failed to load the assembly CLRHostPlugin: 0x80131018
01:16:01: CLRHost::LoadPlugins() attempting to load the plugin assembly MumbleOverlayPlugin
01:16:01: CLRHost::LoadPlugins() successfully added CLR plugin [Type: MumbleOverlayPlugin.MumbleOverlayPlugin, Name: Mumble Overlay Plugin]
01:16:01: Video Source Plugin strings not found, dynamically loading 52 strings
01:16:14: Open Broadcaster Software v0.651b - 32bit (´・ω・`)
01:16:14: -------------------------------
01:16:14: CPU Name: Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz
01:16:14: CPU Speed: 3818MHz
01:16:14: Physical Memory: 4095MB Total, 4095MB Free
01:16:14: stepping id: 2, model 63, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 16, total cores 8
01:16:14: monitor 1: pos={0, 0}, size={1920, 1080}
01:16:14: Windows Version: 6.2 Build 9200
01:16:14: Aero is Enabled
01:16:14: OBS Modules:
01:16:14: Base Address Module
01:16:14: 00940000 OBS.exe
01:16:14: 6A560000 OBSApi.dll
01:16:14: 6A310000 CLRHostPlugin.dll
01:16:14: 5FED0000 DShowPlugin.dll
01:16:14: 69FA0000 GraphicsCapture.dll
01:16:14: 61E80000 NoiseGate.dll
01:16:14: 6A2F0000 PSVPlugin.dll
01:16:14: 5FEB0000 scenesw.dll
01:16:14: 73220000 VideoSourcePluginWrapper.dll
01:16:14: ------------------------------------------
01:16:14: Adapter 1
01:16:14: Video Adapter: NVIDIA GeForce GTX 980
01:16:14: Video Adapter Dedicated Video Memory: 3221225472
01:16:14: Video Adapter Shared System Memory: 1073676288
01:16:14: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
01:16:14: =====Stream Start: 2015-04-28, 01:16:14===============================================
01:16:14: Multithreaded optimizations: On
01:16:14: Base resolution: 1920x1080
01:16:14: Output resolution: 1920x1080
01:16:14: Loading up D3D10 on NVIDIA GeForce GTX 980 (Adapter 1)...
01:16:14: Audio Format: 48000 Hz
01:16:14: Audio Channels: 2 Ch
01:16:14: Playback device {0.0.0.00000000}.{88c46a62-97e3-4b16-ba87-a537637f3c05}
01:16:14: Using desktop audio input: CABLE-A Input (VB-Audio Cable A)
01:16:14: Global Audio time adjust: 0
01:16:14: Using auxilary audio input: CABLE-B Output (VB-Audio Cable B)
01:16:14: Mic time offset: 0
01:16:14: Audio Encoding: AAC
01:16:14: bitrate: 160
01:16:14: device: SA7160 PCI, Analog 01 Capture,
01:16:14: device id \\?\pci#ven_1131&dev_7160&subsys_12abe517&rev_03#6&1eadc0e5&0&00080018#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{6f814be9-9af6-43cf-9249-c0340100021c},
01:16:14: chosen type: YUY2, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 166833-333667
01:16:14: use buffering: false - 0, fourCC: 'YUY2'
01:16:14: audio device: SA7160 PCI, Analog 01 WaveIn,
01:16:14: audio device id \\?\pci#ven_1131&dev_7160&subsys_12abe517&rev_03#6&1eadc0e5&0&00080018#{33d9a762-90c8-11d0-bd43-00a0c911ce86}\{6f814be9-9af6-43cf-9249-c0340100031c},
01:16:14: audio time offset 0,
01:16:14:
01:16:14: Using directshow input
01:16:14: device: Datapath VisionDVI-DL Video 01,
01:16:14: device id (null),
01:16:14: chosen type: YUY2, usingFourCC: false, res: 320x240 - 4096x4096, frameIntervals: 1000-10000000
01:16:14: audio device: Line In (Realtek High Definition Audio),
01:16:14: audio device id (null),
01:16:14:
01:16:14: device audio info - bits per sample: 16, channels: 2, samples per sec: 44100, block size: 4
01:16:14: Scene buffering time set to 700
01:16:14: Video Encoding: x264
01:16:14: fps: 30
01:16:14: width: 1920, height: 1080
01:16:14: preset: medium
01:16:14: profile: main
01:16:14: keyint: 60
01:16:14: CBR: yes
01:16:14: CFR: yes
01:16:14: max bitrate: 5000
01:16:14: buffer size: 5000
01:17:49: Total frames encoded: 2815, total frames duplicated: 0 (0.00%)
01:17:49: Total frames rendered: 2839, number of late frames: 1 (0.04%) (it's okay for some frames to be late)
01:17:50:
01:17:50: Profiler time results:
01:17:50:
01:17:50: ==============================================================
01:17:50: video thread frame - [100%] [avg time: 3.159 ms] [children: 87.2%] [unaccounted: 12.8%]
01:17:50: | scene->Preprocess - [83.9%] [avg time: 2.65 ms]
01:17:50: | GPU download and conversion - [3.36%] [avg time: 0.106 ms] [children: 3.07%] [unaccounted: 0.285%]
01:17:50: | | flush - [2.69%] [avg time: 0.085 ms]
01:17:50: | | CopyResource - [0.19%] [avg time: 0.006 ms]
01:17:50: | | conversion to 4:2:0 - [0.19%] [avg time: 0.006 ms]
01:17:50: Convert444Threads - [100%] [avg time: 0.362 ms] [children: 98.3%] [unaccounted: 1.66%]
01:17:50: | Convert444toNV12 - [98.3%] [avg time: 0.356 ms]
01:17:50: encoder thread frame - [100%] [avg time: 1.589 ms] [children: 0.126%] [unaccounted: 99.9%]
01:17:50: | sending stuff out - [0.126%] [avg time: 0.002 ms]
01:17:50:
01:17:50:
01:17:50: Profiler CPU results:
01:17:50:
01:17:50: video thread frame - [cpu time: avg 2.542 ms, total 7218.75 ms] [avg calls per frame: 1]
01:17:50: | scene->Preprocess - [cpu time: avg 2.3 ms, total 6531.25 ms] [avg calls per frame: 1]
01:17:50: | GPU download and conversion - [cpu time: avg 0.055 ms, total 156.25 ms] [avg calls per frame: 1]
01:17:50: | | flush - [cpu time: avg 0.049 ms, total 140.625 ms] [avg calls per frame: 1]
01:17:50: | | CopyResource - [cpu time: avg 0.005 ms, total 15.625 ms] [avg calls per frame: 1]
01:17:50: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
01:17:50: Convert444Threads - [cpu time: avg 0.479 ms, total 8109.38 ms] [avg calls per frame: 6]
01:17:50: | Convert444toNV12 - [cpu time: avg 0.477 ms, total 8062.5 ms] [avg calls per frame: 6]
01:17:50: encoder thread frame - [cpu time: avg 1.143 ms, total 3218.75 ms] [avg calls per frame: 1]
01:17:50: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
01:17:50:
01:17:50: =====Stream End: 2015-04-28, 01:17:50=================================================
01:17:50: CLR host plugin instance deleted; removing dynamically loaded localization strings
01:17:50: Video Source Plugin instance deleted; removing dynamically loaded localization strings
01:17:50: Terminating 0x1ab0
