cyrofault
Hello!
I like to sing along to music while I'm streaming. I'm using Adobe Audition to process the input from my microphone and then output it to Virtual Audio Cable. My problem is that the microphone falls behind the desktop audio, but the webcam seems to stay in sync with the microphone. (I noticed this while watching a recording of one of my streams.) The synchronization is perfect when I'm not using Audition, but I'd really prefer to keep using Audition if I can. I've tried changing the scene buffering from the range of 400 ms to 2000 ms, all with the same results. I've also tried setting the microphone delay from 200 ms to 3000 ms, and it doesn't seem to make a difference. What do I need to do?
The first log is without the Audition processing (should be using Yeti Stereo for mic input) and the second does (should use Virtual Audio Cable).
Thank you for your help!
