Hi all. not so long ago I tried to play the guitar on stream with music clips together and at the beginning there were no delays between guitar and music from browser, but over some time (~30 mins) the sound of the guitar began to delay. I don't understand what the problem is. i use reaper and focusrite solo 3rd gen. in reaper i added FX vst plugins with distortion etc, then sound from reaper goes to obs as "asio input capture" via rearoute plugin (monitor off in advanced audio settings). i made a copy of this asio capture as monitor output (monitor only) to hear the guitar on stream. also i added app audio capture (beta) for opera browser in order to avoid copyright (no music on recorded broadcasts). so while im playing online i hear guitar monitor and music from browser and I play beat to beat. sound of guitar monitor doesnt delay throughout the stream but on recorded broadcast it starts to delay after a while. im almost sure that problem is not in reaper, but in obs. Because if i restart reaper - nothing changes, but if i restart obs - delay is gone, and then after some time it comes back again. i assume there is some buffer which start to overfill after a while. maybe i can manually reset that buffer without turning off stream and restarting obs..? maybe someone already met with this problem?
PC config: Ryzen 3700x, 3070ti, headset - fifine ampligame h6 (USB, yes i have no jack headphones), motherboard MSI Gaming plus max B450, RAM Corsair Vengeance 4x8Gb 3600MHz DDR4, sound card focusrite solo 3rd gen
