Audio Default Settings Not Saving Between Restarts
MaxusDetriment
I'm new to OBS, my setup has two Elgato HD60 S capture cards and I'm handling audio through the analog connector on one of the cards. It outputs from a soundboard to the analog slot on the card. Whenever I launch OBS, it starts pulling audio through the HDMI which causes issues. If I close OBS, load the 4K Capture Utility from Elgato and go to audio settings, it's still set to analog input. If I toggle it to HDMI and back to Analog, it will fix it on OBS. I get the feeling it's OBS, not Elgato, because Elgato is holding the settings. Any suggestions on what to do so I don't have to instruct my team to jump through several hoops to make this work?
