Question / Help Audio cutting out randomly - generally around 25-40 min
jpopejoy41
I'm having issues with the audio cutting out randomly. I had this issue previously, then an update seemed to have fixed it and not it's back. The meters are working fine, and then it just stops. When I close OBS and reopen, it's fine again.
Here is the log: https://obsproject.com/logs/VmM8PvmiKwfJ3v6B
Things I've tried so far:
double checked my sample rate from input and OBS is the same (it is)
Windows Power plan to not shut off USB
Deleted secondary antivirus, and disabled Windows Defender real-time protector
ran OBS in Admin mode
uninstalled reinstalled both OBS and the focusrite drivers
I'm using a Focusrite Scarlet 2i2 3rd gen - with updated drivers.
I looks like OBS starts to increase CPU usage and then it cuts out - while visually watching, I don't see the total hit 100%, I click on the performance stream tab and do see a brief peak to 100%.
Then I switched from x264 to QuickSync and ran again. Was improved with CPU usage, and this time it made it 55 min, but still went out on a quick CPU spike from OBS.
I had similar tonight using OBS 25.0.7 OSX 10.15.4.
I was using a Focusrite Scarlet 2i2, using both jack inputs from a Pioneer DJM Nexus 2. Audio was cutting out every 20 - 45s, swapped USBs, Swapped USB ports, restarted OBS and nothing. Did a full mac OS X restart and it fixed the audio cut out issue... however my CPU was way over average, i normally operate below 20% but tonight using my 2i2 i was over 50%, sometimes hitting 80%.
Going to test the same setup on my windows machine tomorrow and see if there are any similarities.
The issue I was having was similar but with a few differences
OBS 26.1.0, Windows 10, Focusrite Scarlett 2i2 3rd gen, connecting a mixing board to the inputs of the Scarlett, also connecting a JVC video camera to the computer through an HDMI to USB adapter and capturing the audio as a back up to the Scarlett. The video camera was using another analog output from the mixing board to its 1/8" microphone jack. (this always needed to be connected to USB 2.0)
Had previously been using Gen 2 on loan without an issue but then switched to the Gen 3. The computer "seemed" to find the drivers so we proceeded. The audio would quit after as little as 5 minutes or as long as 20 minutes (levels on OBS dropped to zero). If you just plugged and unplugged the Scarlett it would come back again and OBS would just keep running. I then tried the same audio setup with the jamming software Jamulus and it wouldn't work. I downloaded the ASIO drivers from the Focusrite website and that resolved the Jamulus problem and also it seems the OBS problem. My fault for now being more careful with the drivers. One strange thing: an older Gen 3 seemed to work fine for OBS.
