peaceandkwiat
For the past few months I have been having ongoing audio issues. Stream starts off fine, about 6-15 minutes in the audio will cut out for about 30 seconds and then comes back delayed and no longer synced with the video. I wanted to start doing audio production on stream using Ableton Live and was looking for a software that could have my audio from Ableton feed into OBS. I upgraded from my Scarlett Focusrite Solo 2nd generation, to a 2i2 3rd generation and then 4i4 3rd generation audio interfaces, with and without my Yamaha AG-06. I adjusted performance settings on the computer, switch the USB cables to different ports on the computer, tried a powered USB hub, and made sure my bit and sample rates all matched an all devices. I reinstalled OBS, my interface drivers, Ableton, and even reinstalled Windows to start from scratch and rebuild my OBS setup. The audio would still cut out after a few minutes of the stream starting. Today, I tried to stream without an interface plugged and used the audio from my Logitech BRIO webcam and had no audio issues for the entire duration of the stream. I'm also having a visual glitch on the webcam, even after switching the cables and trying different video settings. I tried a second stream with my Focusrite 4i4 interface with my AT2020 condenser microphone (one that I used before with no problems) and about 7 minutes in the audio cut out again. I've included the logs to both streams below.
Any help would be greatly appreciated, thank you!!
Log with audio from BRIO webcam: https://obsproject.com/logs/vgWnMVLL22upS8go
Log with audio from 4i4 interface and condenser microphone: https://obsproject.com/logs/1BrA7x_6QR72iVo_
