Bug Report Audio Crackling when Starting Stream ( not only when starting )
Aldonoba
Hello,
I have a wierd Bug going on. If i start the Stream or test the Stream i get a strange Bug. The Audio is bumping up and down in a rythmic way. ( it´s not really the audio it´s just a signal that makes click click click click )
Then after 5 seconds it stops and i have the normal game sound.Then while i´m streaming, it comes back after 5-10 minutes and starts to do click click click click in a rythmic way again.
i tried to lower the resolution of the capture card but without succes yet.
It even keeps Clicking or cracking in a rythmic way when i dont even have any audio cable in the capture card. it´s kinda wierd..
I´m pretty sure it has to be a fault with the Dazzle. But i don´t know what´s going on to be honest.
No problems though if the Dazzle isn´t connected. The dazzle is anyway Usb 2.0 so i guess putting it on a usb 3.0 wouldn´t change a thing.
Can someone help me please?
Log:
https://gist.github.com/anonymous/1b38eeb5dea96f57e070#file-2014-12-05-0235-27-log
