THANK YOU SO SO MUCH, you don’t even understand how helpful this was. I’ve spent 2 weeks trying to figure out what was wrong with my mic not knowing that I needed to do this change. You literally are amazing, tysmHi all, I'm new to OBS but have been trying recording on M1 MacBook Air and having problems with crackling audio from any source. Was driving me nuts. Eventually discovered that in the Settings/Output/Recording/Type option, changing this from "Standard" to "Custom Output (FFmpeg)" completely solved the issue. Audio now records without glitches. Hope that helps someone.
similar problem with streamed audio to YouTube. audio came back 'crackly' if that is a word. Using 24" M1 Mac, running audio from mixer to PTZ NDI/HX camera, then streaming out to Youtube via OBS. Eliminated distortion by: audio source/properties/bandwidth...changed 'highest' to 'lowest' or 'Audio only'.
Thanks a lot for this solution. I had same issue on Mac Mini 2018 but once i changed to custom output (FFmpeg) sound is perfect.. My system on Mac os 12.2.1 MontereyHi all, I'm new to OBS but have been trying recording on M1 MacBook Air and having problems with crackling audio from any source. Was driving me nuts. Eventually discovered that in the Settings/Output/Recording/Type option, changing this from "Standard" to "Custom Output (FFmpeg)" completely solved the issue. Audio now records without glitches. Hope that helps someone.
