Question / Help Audio Changes Volume/(Quality?) Depending on Headphones Plugged In or Not
Exaskryz
Hello OBS community!
This is not necessarily a problem to be solved because I have a workaround, but I am curious about the underlying mechanics of it.
So I am using OBS as a desktop recorder, not for streaming atm. I started up my recording, and realized I left the sound on when I actually wanted to mute it. But I didn't want to press mute and get the muting overlay from my PC in the recording (audio would be unaffected), so I compromised by just plugging in headphones that I wouldn't wear - no visual indicators happen that way.
But playing back the video to test, the audio is much louder. I can't exactly tell if there's any change in the audio quality, or if it's just a lot louder.
Here is an example using some free music from a redditor /u/MrLoop:
https://www.youtube.com/watch?v=th1U5KX9QFo
In this video there may be some change to bass, where it gets louder when earbuds are plugged in, I'm not sure. It might have more reverb? IDK, but something changes.
I start with the earbuds unplugged for 25 seconds, then plug them in for 25 seconds (repeating the same audio portion of the song), and then every 5 seconds un/plug them on the third playthrough of the audio sample.
I also show my settings for OBS in case anything jumps out at anybody.
My workaround of course is just not plugging in my headphones to avoid this change in quality.
