Question / Help Audio and Output not working
Narcogen
The log seems to indicate you've configured the device to not capture audio:
14:43:44.794: [DShow Device: 'Capture Card'] settings updated:
14:43:44.794: video device: Game Capture HD60 S (Video) (#01)
14:43:44.794: video path: \\?\usb#vid_0fd9&pid_005e#0113fc3457#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{6f814be9-9af6-43cf-9249-c0340100021f}
14:43:44.794: resolution: 1280x720
14:43:44.794: fps: 60.00 (interval: 166666)
14:43:44.794: format: YV12
14:43:44.805: using video device audio: no
14:43:44.805: separate audio filter
14:43:44.805: sample rate: 48000
14:43:44.805: channels: 2
14:43:44.805: audio type: DirectSound
rburcky
Fiddling around with mine a little but and I ran across a setting in the camera properties that says "Use custom audio device" I put a check in the box and selected my camera and now, when I have audio, the audio indicator bars move like it is picking up the audio, but when I do a recording, I don't appear to be recording any of the audio, as nothing plays back
eg03
I was messing around with mind im not sure if you solved it already but I disabled the "desktop audio"s and the mics or whatever in settings which meant that the only source of audio was the one I added in sources (my headphones) and that for some reason worked. I'm not sure if its permanent bc my audio was working fine yesterday and I changed nothing since then but hopefully this will somehow help lol
