Question / Help Applications audio problem
ScrappyCocco
Hi everyone :) i'm scrappy.
I have a problem: my headphones have a very hight volume, so i usually play with game's audio set at 2/100 on the windows mixer(and i'm serious, it's still quite hight).
The problem then appear: the audio is hight only for me, because obs catch the volume at 2 (i think) and then in the stream there is only my voice and a very little little sound from games and skype xD
What do you suggest to make everything at right volume? Thanks guys!
I already tried the filter to increase volume in obs but 30 of increasing is not enought..
I hope to get some help :(
Have you considered buying an in-line volume control for your headphones? They usually aren't too expensive, about $5-10.
In the meantime you may be able to go into OBS Settings->Audio and set the Desktop Boost (multiple) up by a few; not sure if this was the 'filter' you mentioned. If you're on OBS Studio, this is the wrong forum, but there's not enough information in your post to determine that.
