I have a few sources that I needed to add a 'Video Delay' filter of about 3000ms to, however when I added these filters to my test source, the output would speed up and slow down considerably, until it eventually desync'd from the audio. Even using small delays of like 1000ms or 100ms was causing LESS but still some problems.
When I took off the filter, it was perfectly fine again. The sources I'm adding the filter to are 'ndi-source' plugin sources, but I'm not sure if that would have an effect on it. Whether or not it is because of ndi-source, I still need the delay on ndi-source and I don't think the developer would be able to fix this, which is why I'm here. I'm also running a 1080Ti so I have more than enough VRAM to run these delays, which I read was a problem in another thread.
Is there anything else I can try? Anymore information?
