Killerhands
Hey,
So, I mainly dabble in SDI capture cards (BlackMagic flavor) and I was wondering if there was any way in OBS to boost the embedded audio volume from these SDI sources?
In XSplit there's a bit of a hack you can do by inserting 'micvolrange=xxx' in the shortcut target of the program and you can boost the embedded audio source audio using this method. (link: https://support.xsplit.com/forum/viewtopic.php?p=54923#p54923 )
I'm wondering if there's some sort of way to implement something like what Xsplit does into OBS. I know OBS has the ability to boost mic/aux and desktop audio, but neither of those affect an embedded audio source it seems (either through HDMI or HDSDI).
Thanks,
Killerhands
Thanks,
Killerhands
