7900XTX 4k60fps recording help
RobTheSlob4170
My son is starting out with recording and I have nailed the settings for 1080p60 recording. When I try to record in 4k60 I get brutal lag. I'm currently running a 5900x with 32GB ram and the 7900XTX. I'm trying to encode in AV1 as its the newest encoder. I'm not sure what settings to change to make it run smooth as many reviewers have said that it can do the recording but not a single one posts settings. I'm using the most up to date OBS and I have dual 4k monitor set up but only recording one of them. I can attach images or logs or information later - I'm at work right now but wanted to get something started. Lots of threads here about NVidia is better -Maybe true, but I'm not working with that. I'm trying to make it work with what I have. Both have separate AV1 encoders on them so not sure what makes one better than the other, other than small quality adjustments. maybe I'm dumb here but the AV1 encoder has nothing to do with the gaming part of the card... even old 5700xt's have little to no frame drop encoding.
Im looking for people who have the same hardware and are outputting the same quality videos - or know how. Preferably not opinions or what people dont have first hand knowledge.
Is it normal for the vram to be all used up when gaming and encoding? 24gb is a lot to have used. looks like the codec engine is being used almost fully from the task manager window
