Question / Help 60fps ingame, 4fps stream. Problem? I think so.
Volatar
Trying to get some streaming capability going on an older desktop my best friend gave me.
First I tried broadcasting Hearthstone and OBS would hit 75% of my CPU power and still fail to Stream much. Fixed that by downscaling just a little (1.25), dropping the CPU usage down to about 25%. Smooth stream.
Then I moved over to World of Tanks. And was not so lucky for it to work as well.
While I have 60fps ingame, OBS streams at a framerate of 2-5. Even though it's CPU usage is the same as when streaming Hearthstone. And I still have processor power to spare while running WoT and OBS, so it seems strange to be so completely terrible.
Here is a screenshot. Second monitor on the left with performance monitoring and OBS, and the game on the right: http://i.imgur.com/xmT4A4G.jpg
Here is the log file. It is a mess and really long because I kept starting and stopping the stream, changing various settings to try and see if I could fix it.
23:17:56: Open Broadcaster Software v0.592b - 32bit (´・ω・`)
23:17:56: -------------------------------
23:17:56: CPU Name: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
23:17:56: CPU Speed: 2400MHz
23:17:56: Physical Memory: 3071MB Total, 1541MB Free
23:17:56: stepping id: 11, model 15, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 4, total cores 4
23:17:56: monitor 1: pos={-1280, 0}, size={1280, 1024}
23:17:56: monitor 2: pos={0, 0}, size={1680, 1050}
23:17:56: Windows Version: 6.1 Build 7601 S
23:17:56: Aero is Enabled
23:17:56: OBS Modules:
23:17:56: Base Address Module
23:17:56: 00350000 OBS.exe
23:17:56: 70CA0000 OBSApi.dll
23:17:56: 741E0000 DShowPlugin.dll
23:17:56: 74890000 GraphicsCapture.dll
23:17:56: 74870000 NoiseGate.dll
23:17:56: 74660000 PSVPlugin.dll
23:17:56: ------------------------------------------
23:17:56: Adapter 1
23:17:56: Video Adapter: NVIDIA GeForce 8600 GT
23:17:56: Video Adapter Dedicated Video Memory: 521732096
23:17:56: Video Adapter Shared System Memory: 1341837312
23:17:56: Video Adapter Output 1: pos={0, 0}, size={1680, 1050}, attached=true
23:17:56: Video Adapter Output 2: pos={-1280, 0}, size={1280, 1024}, attached=true
23:17:56: =====Stream Start: 2014-01-21, 23:17:56===============================================
23:17:56: Multithreaded optimizations: On
23:17:56: Base resolution: 1680x1050
23:17:56: Output resolution: 1344x840
23:17:56: Loading up D3D10 on NVIDIA GeForce 8600 GT (Adapter 1)...
23:17:56: Audio Format: 48000hz
23:17:56: Playback device Default
23:17:56: Using desktop audio input: Speakers (High Definition Audio Device)
23:17:56: Using auxilary audio input: Microphone (High Definition Audio Device)
23:17:56: Audio Encoding: AAC
23:17:56: bitrate: 128
23:17:56: Using graphics capture
23:17:56: Scene buffering time set to 400
23:17:56: Video Encoding: x264
23:17:56: fps: 30
23:17:56: width: 1344, height: 840
23:17:56: preset: veryfast
23:17:56: profile: high
23:17:56: keyint: 60
23:17:56: CBR: yes
23:17:56: CFR: yes
23:17:56: max bitrate: 2000
23:17:56: buffer size: 2000
23:17:56: MMDeviceAudioSource: Frequency for device 'Speakers (High Definition Audio Device)' is 352800, samples per sec is 44100
23:17:56: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
23:17:57: SharedTexCapture hooked
23:17:57: Using RTMP service: Twitch / Justin.tv
23:17:57: Server selection: rtmp://live-iad.justin.tv/app
23:17:57: Interface: Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) #2 (ethernet, 1000 mbps)
23:17:58: Completed handshake with rtmp://live-iad.justin.tv/app in 275 ms.
23:17:58: SO_SNDBUF was at 8192
23:17:58: SO_SNDBUF is now 65536
23:18:00: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 7798 / 272384)
23:23:53: Total frames encoded: 10702, total frames duplicated: 9443 (88.24%)
23:23:53: Total frames rendered: 1271, number of late frames: 1128 (88.75%) (it's okay for some frames to be late)
23:23:53: RTMPPublisher::SocketLoop: Aborting due to WSAEnumNetworkEvents failure, 10038
23:23:53: Average send payload: 8930 bytes, average send interval: 33 ms
23:23:53: Number of times waited to send: 0, Waited for a total of 0 bytes
23:23:53: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
23:23:53: Number of bytes sent: 94377303
23:23:53:
23:23:53: Profiler time results:
23:23:53:
23:23:53: ==============================================================
23:23:53: video thread frame - [100%] [avg time: 278.477 ms] [children: 99.5%] [unaccounted: 0.532%]
23:23:53: | scene->Preprocess - [0.0018%] [avg time: 0.005 ms]
23:23:53: | GPU download and conversion - [99.5%] [avg time: 276.991 ms] [children: 100%] [unaccounted: -0.925%]
23:23:53: | | flush - [0.117%] [avg time: 0.325 ms]
23:23:53: | | CopyResource - [100%] [avg time: 279.11 ms]
23:23:53: | | conversion to 4:2:0 - [0.0478%] [avg time: 0.133 ms]
23:23:53: Convert444Threads - [100%] [avg time: 3.141 ms] [children: 98.8%] [unaccounted: 1.21%]
23:23:53: | Convert444toNV12 - [98.8%] [avg time: 3.103 ms]
23:23:53: encoder thread frame - [100%] [avg time: 3.791 ms]
23:23:53:
23:23:53:
23:23:53: Profiler CPU results:
23:23:53:
23:23:53: video thread frame - [cpu time: avg 13.709 ms, total 17425.3 ms] [avg calls per frame: 1]
23:23:53: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:23:53: | GPU download and conversion - [cpu time: avg 12.863 ms, total 16348.9 ms] [avg calls per frame: 1]
23:23:53: | | flush - [cpu time: avg 0.282 ms, total 358.806 ms] [avg calls per frame: 1]
23:23:53: | | CopyResource - [cpu time: avg 12.671 ms, total 15927.7 ms] [avg calls per frame: 1]
23:23:53: | | conversion to 4:2:0 - [cpu time: avg 0.024 ms, total 31.2 ms] [avg calls per frame: 1]
23:23:53: Convert444Threads - [cpu time: avg 2.813 ms, total 7066.85 ms] [avg calls per frame: 2]
23:23:53: | Convert444toNV12 - [cpu time: avg 2.788 ms, total 7004.45 ms] [avg calls per frame: 2]
23:23:53: encoder thread frame - [cpu time: avg 3.172 ms, total 33914.6 ms] [avg calls per frame: 1]
23:23:53:
23:23:53: =====Stream End: 2014-01-21, 23:23:53=================================================
23:24:09: =====Stream Start: 2014-01-21, 23:24:09===============================================
23:24:09: Multithreaded optimizations: On
23:24:09: Base resolution: 1680x1050
23:24:09: Output resolution: 1344x840
23:24:09: ------------------------------------------
23:24:09: Loading up D3D10 on NVIDIA GeForce 8600 GT (Adapter 1)...
23:24:09: Audio Format: 48000hz
23:24:09: Playback device Default
23:24:09: Using desktop audio input: Speakers (High Definition Audio Device)
23:24:09: Using auxilary audio input: Microphone (High Definition Audio Device)
23:24:09: Audio Encoding: AAC
23:24:09: bitrate: 128
23:24:09: Using graphics capture
23:24:09: Scene buffering time set to 400
23:24:09: Video Encoding: x264
23:24:09: fps: 30
23:24:09: width: 1344, height: 840
23:24:09: preset: veryfast
23:24:09: profile: main
23:24:09: keyint: 60
23:24:09: CBR: yes
23:24:09: CFR: yes
23:24:09: max bitrate: 2000
23:24:09: buffer size: 2000
23:24:09: MMDeviceAudioSource: Frequency for device 'Speakers (High Definition Audio Device)' is 352800, samples per sec is 44100
23:24:09: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
23:24:11: SharedTexCapture hooked
23:24:11: Using RTMP service: Twitch / Justin.tv
23:24:11: Server selection: rtmp://live-iad.justin.tv/app
23:24:11: Interface: Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) #2 (ethernet, 1000 mbps)
23:24:11: Completed handshake with rtmp://live-iad.justin.tv/app in 248 ms.
23:24:12: SO_SNDBUF was at 8192
23:24:12: SO_SNDBUF is now 65536
23:24:13: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 0 / 272384)
23:24:14: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 0 / 272384)
23:24:45: Total frames encoded: 1061, total frames duplicated: 875 (82.47%)
23:24:45: Total frames rendered: 193, number of late frames: 106 (54.92%) (it's okay for some frames to be late)
23:24:45: RTMPPublisher::SocketLoop: Graceful loop exit
23:24:45: Average send payload: 7517 bytes, average send interval: 28 ms
23:24:45: Number of times waited to send: 0, Waited for a total of 0 bytes
23:24:45: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
23:24:45: Number of bytes sent: 8600509
23:24:45:
23:24:45: Profiler time results:
23:24:45:
23:24:45: ==============================================================
23:24:45: video thread frame - [100%] [avg time: 173.705 ms] [children: 98.7%] [unaccounted: 1.32%]
23:24:45: | scene->Preprocess - [0.0023%] [avg time: 0.004 ms]
23:24:45: | GPU download and conversion - [98.7%] [avg time: 171.412 ms] [children: 108%] [unaccounted: -8.84%]
23:24:45: | | flush - [0.106%] [avg time: 0.184 ms]
23:24:45: | | CopyResource - [107%] [avg time: 186.442 ms]
23:24:45: | | conversion to 4:2:0 - [0.0864%] [avg time: 0.15 ms]
23:24:45: Convert444Threads - [100%] [avg time: 3.394 ms] [children: 98.1%] [unaccounted: 1.92%]
23:24:45: | Convert444toNV12 - [98.1%] [avg time: 3.329 ms]
23:24:45: encoder thread frame - [100%] [avg time: 3.869 ms]
23:24:45:
23:24:45:
23:24:45: Profiler CPU results:
23:24:45:
23:24:45: video thread frame - [cpu time: avg 12.69 ms, total 2449.22 ms] [avg calls per frame: 1]
23:24:45: | scene->Preprocess - [cpu time: avg 0.08 ms, total 15.6 ms] [avg calls per frame: 1]
23:24:45: | GPU download and conversion - [cpu time: avg 11.72 ms, total 2262.02 ms] [avg calls per frame: 1]
23:24:45: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:24:45: | | CopyResource - [cpu time: avg 12.779 ms, total 2262.02 ms] [avg calls per frame: 1]
23:24:45: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:24:45: Convert444Threads - [cpu time: avg 2.747 ms, total 967.206 ms] [avg calls per frame: 2]
23:24:45: | Convert444toNV12 - [cpu time: avg 2.747 ms, total 967.206 ms] [avg calls per frame: 2]
23:24:45: encoder thread frame - [cpu time: avg 3.301 ms, total 3463.22 ms] [avg calls per frame: 1]
23:24:45:
23:24:45: =====Stream End: 2014-01-21, 23:24:45=================================================
23:24:58: Settings::Video: Enabling Aero
23:25:01: =====Stream Start: 2014-01-21, 23:25:01===============================================
23:25:01: Multithreaded optimizations: On
23:25:01: Base resolution: 1680x1050
23:25:01: Output resolution: 960x600
23:25:01: ------------------------------------------
23:25:01: Loading up D3D10 on NVIDIA GeForce 8600 GT (Adapter 1)...
23:25:01: Audio Format: 48000hz
23:25:01: Playback device Default
23:25:01: Using desktop audio input: Speakers (High Definition Audio Device)
23:25:01: Using auxilary audio input: Microphone (High Definition Audio Device)
23:25:01: Audio Encoding: AAC
23:25:01: bitrate: 128
23:25:01: Using graphics capture
23:25:01: Scene buffering time set to 400
23:25:01: Video Encoding: x264
23:25:01: fps: 30
23:25:01: width: 960, height: 600
23:25:01: preset: veryfast
23:25:01: profile: main
23:25:01: keyint: 60
23:25:01: CBR: yes
23:25:01: CFR: yes
23:25:01: max bitrate: 2000
23:25:01: buffer size: 2000
23:25:01: MMDeviceAudioSource: Frequency for device 'Speakers (High Definition Audio Device)' is 352800, samples per sec is 44100
23:25:01: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
23:25:02: SharedTexCapture hooked
23:25:02: Using RTMP service: Twitch / Justin.tv
23:25:02: Server selection: rtmp://live-iad.justin.tv/app
23:25:02: Interface: Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) #2 (ethernet, 1000 mbps)
23:25:03: Completed handshake with rtmp://live-iad.justin.tv/app in 277 ms.
23:25:04: SO_SNDBUF was at 8192
23:25:04: SO_SNDBUF is now 65536
23:25:04: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 4669 / 272384)
23:25:39: Total frames encoded: 1131, total frames duplicated: 819 (72.41%)
23:25:39: Total frames rendered: 320, number of late frames: 211 (65.94%) (it's okay for some frames to be late)
23:25:39: RTMPPublisher::SocketLoop: Graceful loop exit
23:25:39: Average send payload: 7068 bytes, average send interval: 26 ms
23:25:39: Number of times waited to send: 0, Waited for a total of 0 bytes
23:25:39: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
23:25:39: Number of bytes sent: 9358146
23:25:39:
23:25:39: Profiler time results:
23:25:39:
23:25:39: ==============================================================
23:25:39: video thread frame - [100%] [avg time: 109.544 ms] [children: 98.8%] [unaccounted: 1.17%]
23:25:39: | scene->Preprocess - [0.00274%] [avg time: 0.003 ms]
23:25:39: | GPU download and conversion - [98.8%] [avg time: 108.263 ms] [children: 104%] [unaccounted: -4.78%]
23:25:39: | | flush - [0.172%] [avg time: 0.188 ms]
23:25:39: | | CopyResource - [103%] [avg time: 113.226 ms]
23:25:39: | | conversion to 4:2:0 - [0.0758%] [avg time: 0.083 ms]
23:25:39: Convert444Threads - [100%] [avg time: 1.609 ms] [children: 97.4%] [unaccounted: 2.61%]
23:25:39: | Convert444toNV12 - [97.4%] [avg time: 1.567 ms]
23:25:39: encoder thread frame - [100%] [avg time: 2.005 ms]
23:25:39:
23:25:39:
23:25:39: Profiler CPU results:
23:25:39:
23:25:39: video thread frame - [cpu time: avg 6.24 ms, total 1996.81 ms] [avg calls per frame: 1]
23:25:39: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:25:39: | GPU download and conversion - [cpu time: avg 5.606 ms, total 1794.01 ms] [avg calls per frame: 1]
23:25:39: | | flush - [cpu time: avg 0.292 ms, total 93.6 ms] [avg calls per frame: 1]
23:25:39: | | CopyResource - [cpu time: avg 5.472 ms, total 1669.21 ms] [avg calls per frame: 1]
23:25:39: | | conversion to 4:2:0 - [cpu time: avg 0.051 ms, total 15.6 ms] [avg calls per frame: 1]
23:25:39: Convert444Threads - [cpu time: avg 1.693 ms, total 1029.61 ms] [avg calls per frame: 2]
23:25:39: | Convert444toNV12 - [cpu time: avg 1.693 ms, total 1029.61 ms] [avg calls per frame: 2]
23:25:39: encoder thread frame - [cpu time: avg 1.394 ms, total 1560.01 ms] [avg calls per frame: 1]
23:25:39:
23:25:39: =====Stream End: 2014-01-21, 23:25:39=================================================
23:25:47: Settings::Video: Enabling Aero
23:26:01: =====Stream Start: 2014-01-21, 23:26:01===============================================
23:26:01: Multithreaded optimizations: On
23:26:01: Base resolution: 1680x1050
23:26:01: Output resolution: 1344x840
23:26:01: ------------------------------------------
23:26:01: Loading up D3D10 on NVIDIA GeForce 8600 GT (Adapter 1)...
23:26:01: Audio Format: 48000hz
23:26:01: Playback device Default
23:26:01: Using desktop audio input: Speakers (High Definition Audio Device)
23:26:01: Using auxilary audio input: Microphone (High Definition Audio Device)
23:26:01: Audio Encoding: AAC
23:26:01: bitrate: 128
23:26:01: Using graphics capture
23:26:01: Scene buffering time set to 400
23:26:01: Video Encoding: x264
23:26:01: fps: 30
23:26:01: width: 1344, height: 840
23:26:01: preset: superfast
23:26:01: profile: main
23:26:01: keyint: 60
23:26:01: CBR: yes
23:26:01: CFR: yes
23:26:01: max bitrate: 2000
23:26:01: buffer size: 2000
23:26:01: MMDeviceAudioSource: Frequency for device 'Speakers (High Definition Audio Device)' is 352800, samples per sec is 44100
23:26:01: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
23:26:02: SharedTexCapture hooked
23:26:03: Using RTMP service: Twitch / Justin.tv
23:26:03: Server selection: rtmp://live-iad.justin.tv/app
23:26:03: Interface: Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) #2 (ethernet, 1000 mbps)
23:26:03: Completed handshake with rtmp://live-iad.justin.tv/app in 256 ms.
23:26:04: SO_SNDBUF was at 8192
23:26:04: SO_SNDBUF is now 65536
23:26:05: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 7362 / 272384)
23:26:05: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 0 / 272384)
23:26:40: Total frames encoded: 1160, total frames duplicated: 980 (84.48%)
23:26:40: Total frames rendered: 188, number of late frames: 118 (62.77%) (it's okay for some frames to be late)
23:26:41: RTMPPublisher::SocketLoop: Aborting due to WSAEnumNetworkEvents failure, 10038
23:26:41: Average send payload: 7532 bytes, average send interval: 28 ms
23:26:41: Number of times waited to send: 0, Waited for a total of 0 bytes
23:26:41: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
23:26:41: Number of bytes sent: 9581884
23:26:41:
23:26:41: Profiler time results:
23:26:41:
23:26:41: ==============================================================
23:26:41: video thread frame - [100%] [avg time: 198.116 ms] [children: 99.2%] [unaccounted: 0.805%]
23:26:41: | scene->Preprocess - [0.00202%] [avg time: 0.004 ms]
23:26:41: | GPU download and conversion - [99.2%] [avg time: 196.518 ms] [children: 108%] [unaccounted: -8.99%]
23:26:41: | | flush - [0.123%] [avg time: 0.243 ms]
23:26:41: | | CopyResource - [108%] [avg time: 214 ms]
23:26:41: | | conversion to 4:2:0 - [0.0439%] [avg time: 0.087 ms]
23:26:41: Convert444Threads - [100%] [avg time: 3.121 ms] [children: 99.1%] [unaccounted: 0.929%]
23:26:41: | Convert444toNV12 - [99.1%] [avg time: 3.092 ms]
23:26:41: encoder thread frame - [100%] [avg time: 3.593 ms]
23:26:41:
23:26:41:
23:26:41: Profiler CPU results:
23:26:41:
23:26:41: video thread frame - [cpu time: avg 11.783 ms, total 2215.21 ms] [avg calls per frame: 1]
23:26:41: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:26:41: | GPU download and conversion - [cpu time: avg 10.621 ms, total 1996.81 ms] [avg calls per frame: 1]
23:26:41: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:26:41: | | CopyResource - [cpu time: avg 11.518 ms, total 1981.21 ms] [avg calls per frame: 1]
23:26:41: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:26:41: Convert444Threads - [cpu time: avg 3.785 ms, total 1294.81 ms] [avg calls per frame: 2]
23:26:41: | Convert444toNV12 - [cpu time: avg 3.785 ms, total 1294.81 ms] [avg calls per frame: 2]
23:26:41: encoder thread frame - [cpu time: avg 3.03 ms, total 3478.82 ms] [avg calls per frame: 1]
23:26:41:
23:26:41: =====Stream End: 2014-01-21, 23:26:41=================================================
23:26:48: =====Stream Start: 2014-01-21, 23:26:48===============================================
23:26:48: Multithreaded optimizations: On
23:26:48: Base resolution: 1680x1050
23:26:48: Output resolution: 1344x840
23:26:48: ------------------------------------------
23:26:48: Loading up D3D10 on NVIDIA GeForce 8600 GT (Adapter 1)...
23:26:48: Audio Format: 48000hz
23:26:48: Playback device Default
23:26:48: Using desktop audio input: Speakers (High Definition Audio Device)
23:26:48: Using auxilary audio input: Microphone (High Definition Audio Device)
23:26:48: Audio Encoding: AAC
23:26:48: bitrate: 128
23:26:48: Using graphics capture
23:26:48: Scene buffering time set to 400
23:26:48: Video Encoding: x264
23:26:48: fps: 30
23:26:48: width: 1344, height: 840
23:26:48: preset: ultrafast
23:26:48: profile: main
23:26:48: keyint: 60
23:26:48: CBR: yes
23:26:48: CFR: yes
23:26:48: max bitrate: 2000
23:26:48: buffer size: 2000
23:26:48: MMDeviceAudioSource: Frequency for device 'Speakers (High Definition Audio Device)' is 352800, samples per sec is 44100
23:26:48: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
23:26:49: Using RTMP service: Twitch / Justin.tv
23:26:49: Server selection: rtmp://live-iad.justin.tv/app
23:26:49: Interface: Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) #2 (ethernet, 1000 mbps)
23:26:50: SharedTexCapture hooked
23:26:50: Completed handshake with rtmp://live-iad.justin.tv/app in 295 ms.
23:26:50: SO_SNDBUF was at 8192
23:26:50: SO_SNDBUF is now 65536
23:26:52: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 32372 / 272384)
23:26:52: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 0 / 272384)
23:27:22: Total frames encoded: 994, total frames duplicated: 234 (23.54%)
23:27:22: Total frames rendered: 768, number of late frames: 27 (3.52%) (it's okay for some frames to be late)
23:27:22: RTMPPublisher::SocketLoop: Aborting due to WSAEnumNetworkEvents failure, 10038
23:27:22: Average send payload: 5680 bytes, average send interval: 20 ms
23:27:22: Number of times waited to send: 0, Waited for a total of 0 bytes
23:27:22: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
23:27:22: Number of bytes sent: 8213671
23:27:22:
23:27:22: Profiler time results:
23:27:22:
23:27:22: ==============================================================
23:27:22: video thread frame - [100%] [avg time: 22.799 ms] [children: 96.9%] [unaccounted: 3.05%]
23:27:22: | scene->Preprocess - [0.0307%] [avg time: 0.007 ms]
23:27:22: | GPU download and conversion - [96.9%] [avg time: 22.096 ms] [children: 98.8%] [unaccounted: -1.89%]
23:27:22: | | flush - [0.434%] [avg time: 0.099 ms]
23:27:22: | | CopyResource - [98.3%] [avg time: 22.411 ms]
23:27:22: | | conversion to 4:2:0 - [0.0702%] [avg time: 0.016 ms]
23:27:22: Convert444Threads - [100%] [avg time: 2.581 ms] [children: 99.3%] [unaccounted: 0.697%]
23:27:22: | Convert444toNV12 - [99.3%] [avg time: 2.563 ms]
23:27:22: encoder thread frame - [100%] [avg time: 2.869 ms]
23:27:22:
23:27:22:
23:27:22: Profiler CPU results:
23:27:22:
23:27:22: video thread frame - [cpu time: avg 6.215 ms, total 4773.63 ms] [avg calls per frame: 1]
23:27:22: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:27:22: | GPU download and conversion - [cpu time: avg 6.154 ms, total 4726.83 ms] [avg calls per frame: 1]
23:27:22: | | flush - [cpu time: avg 0.101 ms, total 78 ms] [avg calls per frame: 1]
23:27:22: | | CopyResource - [cpu time: avg 6.14 ms, total 4617.63 ms] [avg calls per frame: 1]
23:27:22: | | conversion to 4:2:0 - [cpu time: avg 0.02 ms, total 15.6 ms] [avg calls per frame: 1]
23:27:22: Convert444Threads - [cpu time: avg 2.575 ms, total 3868.82 ms] [avg calls per frame: 2]
23:27:22: | Convert444toNV12 - [cpu time: avg 2.575 ms, total 3868.82 ms] [avg calls per frame: 2]
23:27:22: encoder thread frame - [cpu time: avg 2.351 ms, total 2308.81 ms] [avg calls per frame: 1]
23:27:22:
23:27:22: =====Stream End: 2014-01-21, 23:27:22=================================================
23:27:36: =====Stream Start: 2014-01-21, 23:27:36===============================================
23:27:36: Multithreaded optimizations: On
23:27:36: Base resolution: 1680x1050
23:27:36: Output resolution: 1344x840
23:27:36: ------------------------------------------
23:27:36: Loading up D3D10 on NVIDIA GeForce 8600 GT (Adapter 1)...
23:27:36: Audio Format: 48000hz
23:27:36: Playback device Default
23:27:36: Using desktop audio input: Speakers (High Definition Audio Device)
23:27:36: Using auxilary audio input: Microphone (High Definition Audio Device)
23:27:36: Audio Encoding: AAC
23:27:36: bitrate: 128
23:27:36: Using graphics capture
23:27:36: Scene buffering time set to 700
23:27:36: Video Encoding: x264
23:27:36: fps: 30
23:27:36: width: 1344, height: 840
23:27:36: preset: veryfast
23:27:36: profile: main
23:27:36: keyint: 60
23:27:36: CBR: yes
23:27:36: CFR: yes
23:27:36: max bitrate: 2000
23:27:36: buffer size: 2000
23:27:36: MMDeviceAudioSource: Frequency for device 'Speakers (High Definition Audio Device)' is 352800, samples per sec is 44100
23:27:36: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
23:27:37: SharedTexCapture hooked
23:27:39: Using RTMP service: Twitch / Justin.tv
23:27:39: Server selection: rtmp://live-iad.justin.tv/app
23:27:39: Interface: Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) #2 (ethernet, 1000 mbps)
23:27:39: Completed handshake with rtmp://live-iad.justin.tv/app in 335 ms.
23:27:40: SO_SNDBUF was at 8192
23:27:40: SO_SNDBUF is now 65536
23:27:42: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 9203 / 272384)
23:27:46: Total frames encoded: 242, total frames duplicated: 155 (64.05%)
23:27:46: Total frames rendered: 95, number of late frames: 24 (25.26%) (it's okay for some frames to be late)
23:27:46: RTMPPublisher::SocketLoop: Graceful loop exit
23:27:46: Average send payload: 7769 bytes, average send interval: 28 ms
23:27:46: Number of times waited to send: 0, Waited for a total of 0 bytes
23:27:46: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
23:27:46: Number of bytes sent: 1041064
23:27:46:
23:27:46: Profiler time results:
23:27:46:
23:27:46: ==============================================================
23:27:46: video thread frame - [100%] [avg time: 79.489 ms] [children: 96.5%] [unaccounted: 3.51%]
23:27:46: | scene->Preprocess - [0.00377%] [avg time: 0.003 ms]
23:27:46: | GPU download and conversion - [96.5%] [avg time: 76.697 ms] [children: 130%] [unaccounted: -34%]
23:27:46: | | flush - [0.204%] [avg time: 0.162 ms]
23:27:46: | | CopyResource - [130%] [avg time: 103.391 ms]
23:27:46: | | conversion to 4:2:0 - [0.221%] [avg time: 0.176 ms]
23:27:46: Convert444Threads - [100%] [avg time: 3.075 ms] [children: 99.1%] [unaccounted: 0.911%]
23:27:46: | Convert444toNV12 - [99.1%] [avg time: 3.047 ms]
23:27:46: encoder thread frame - [100%] [avg time: 3.448 ms]
23:27:46:
23:27:46:
23:27:46: Profiler CPU results:
23:27:46:
23:27:46: video thread frame - [cpu time: avg 6.404 ms, total 608.403 ms] [avg calls per frame: 1]
23:27:46: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:27:46: | GPU download and conversion - [cpu time: avg 6.075 ms, total 577.203 ms] [avg calls per frame: 1]
23:27:46: | | flush - [cpu time: avg 0.164 ms, total 15.6 ms] [avg calls per frame: 1]
23:27:46: | | CopyResource - [cpu time: avg 8.022 ms, total 561.603 ms] [avg calls per frame: 1]
23:27:46: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:27:46: Convert444Threads - [cpu time: avg 2.6 ms, total 358.802 ms] [avg calls per frame: 2]
23:27:46: | Convert444toNV12 - [cpu time: avg 2.6 ms, total 358.802 ms] [avg calls per frame: 2]
23:27:46: encoder thread frame - [cpu time: avg 2.894 ms, total 639.604 ms] [avg calls per frame: 1]
23:27:46:
23:27:46: =====Stream End: 2014-01-21, 23:27:46=================================================
23:28:39: =====Stream Start: 2014-01-21, 23:28:39===============================================
23:28:39: Multithreaded optimizations: On
23:28:39: Base resolution: 1680x1050
23:28:39: Output resolution: 1344x840
23:28:39: ------------------------------------------
23:28:39: Loading up D3D10 on NVIDIA GeForce 8600 GT (Adapter 1)...
23:28:39: Audio Format: 48000hz
23:28:39: Playback device Default
23:28:39: Using desktop audio input: Speakers (High Definition Audio Device)
23:28:39: Using auxilary audio input: Microphone (High Definition Audio Device)
23:28:40: ------------------------------------------
23:28:40: Audio Encoding: AAC
23:28:40: bitrate: 128
23:28:40: Using graphics capture
23:28:40: Scene buffering time set to 400
23:28:40: Video Encoding: x264
23:28:40: fps: 30
23:28:40: width: 1344, height: 840
23:28:40: preset: veryfast
23:28:40: profile: main
23:28:40: keyint: 60
23:28:40: CBR: yes
23:28:40: CFR: yes
23:28:40: max bitrate: 2000
23:28:40: buffer size: 2000
23:28:40: MMDeviceAudioSource: Frequency for device 'Speakers (High Definition Audio Device)' is 352800, samples per sec is 44100
23:28:40: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
23:28:40: SharedTexCapture hooked
23:28:41: Using RTMP service: Twitch / Justin.tv
23:28:41: Server selection: rtmp://live-iad.justin.tv/app
23:28:41: Interface: Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) #2 (ethernet, 1000 mbps)
23:28:41: Completed handshake with rtmp://live-iad.justin.tv/app in 289 ms.
23:28:42: SO_SNDBUF was at 8192
23:28:42: SO_SNDBUF is now 65536
23:28:43: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 7846 / 272384)
23:31:10: Total frames encoded: 4494, total frames duplicated: 3617 (80.49%)
23:31:10: Number of frames skipped due to encoder lag: 6 (0.13%)
23:31:10: Total frames rendered: 916, number of late frames: 497 (54.26%) (it's okay for some frames to be late)
23:31:10: RTMPPublisher::SocketLoop: Aborting due to WSAEnumNetworkEvents failure, 10038
23:31:10: Average send payload: 8674 bytes, average send interval: 32 ms
23:31:10: Number of times waited to send: 0, Waited for a total of 0 bytes
23:31:10: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
23:31:10: Number of bytes sent: 39123001
23:31:10:
23:31:10: Profiler time results:
23:31:10:
23:31:10: ==============================================================
23:31:10: video thread frame - [100%] [avg time: 155.428 ms] [children: 99%] [unaccounted: 1.04%]
23:31:10: | scene->Preprocess - [0.00257%] [avg time: 0.004 ms]
23:31:10: | GPU download and conversion - [99%] [avg time: 153.809 ms] [children: 100%] [unaccounted: -1.53%]
23:31:10: | | flush - [0.196%] [avg time: 0.304 ms]
23:31:10: | | CopyResource - [100%] [avg time: 155.772 ms]
23:31:10: | | conversion to 4:2:0 - [0.0701%] [avg time: 0.109 ms]
23:31:10: Convert444Threads - [100%] [avg time: 3.289 ms] [children: 98.9%] [unaccounted: 1.06%]
23:31:10: | Convert444toNV12 - [98.9%] [avg time: 3.254 ms]
23:31:10: encoder thread frame - [100%] [avg time: 3.979 ms]
23:31:10:
23:31:10:
23:31:10: Profiler CPU results:
23:31:10:
23:31:10: video thread frame - [cpu time: avg 10.133 ms, total 9282.06 ms] [avg calls per frame: 1]
23:31:10: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:31:10: | GPU download and conversion - [cpu time: avg 9.4 ms, total 8611.26 ms] [avg calls per frame: 1]
23:31:10: | | flush - [cpu time: avg 0.153 ms, total 140.401 ms] [avg calls per frame: 1]
23:31:10: | | CopyResource - [cpu time: avg 9.377 ms, total 8439.65 ms] [avg calls per frame: 1]
23:31:10: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:31:10: Convert444Threads - [cpu time: avg 2.906 ms, total 5226.03 ms] [avg calls per frame: 2]
23:31:10: | Convert444toNV12 - [cpu time: avg 2.897 ms, total 5210.43 ms] [avg calls per frame: 2]
23:31:10: encoder thread frame - [cpu time: avg 3.139 ms, total 14071.3 ms] [avg calls per frame: 1]
23:31:10:
23:31:10: =====Stream End: 2014-01-21, 23:31:10=================================================
23:45:52: =====Stream Start: 2014-01-21, 23:45:52===============================================
23:45:52: Multithreaded optimizations: On
23:45:52: Base resolution: 1680x1050
23:45:52: Output resolution: 1344x840
23:45:52: ------------------------------------------
23:45:52: Loading up D3D10 on NVIDIA GeForce 8600 GT (Adapter 1)...
23:45:52: Audio Format: 48000hz
23:45:52: Playback device Default
23:45:52: Using desktop audio input: Headphones (High Definition Audio Device)
23:45:52: Using auxilary audio input: Microphone (High Definition Audio Device)
23:45:52: Audio Encoding: AAC
23:45:52: bitrate: 128
23:45:52: Using graphics capture
23:45:52: Scene buffering time set to 400
23:45:52: Video Encoding: x264
23:45:52: fps: 30
23:45:52: width: 1344, height: 840
23:45:52: preset: veryfast
23:45:52: profile: main
23:45:52: keyint: 60
23:45:52: CBR: yes
23:45:52: CFR: yes
23:45:52: max bitrate: 2000
23:45:52: buffer size: 2000
23:45:52: MMDeviceAudioSource: Frequency for device 'Headphones (High Definition Audio Device)' is 352800, samples per sec is 44100
23:45:52: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
23:45:53: Total frames encoded: 11, total frames duplicated: 1 (9.09%)
23:45:53: Total frames rendered: 28, number of late frames: 1 (3.57%) (it's okay for some frames to be late)
23:45:53:
23:45:53: Profiler time results:
23:45:53:
23:45:53: ==============================================================
23:45:53: video thread frame - [100%] [avg time: 6.319 ms] [children: 86.2%] [unaccounted: 13.8%]
23:45:53: | scene->Preprocess - [0.0475%] [avg time: 0.003 ms]
23:45:53: | GPU download and conversion - [86.1%] [avg time: 5.442 ms] [children: 183%] [unaccounted: -96.8%]
23:45:53: | | flush - [1.91%] [avg time: 0.121 ms]
23:45:53: | | CopyResource - [181%] [avg time: 11.427 ms]
23:45:53: | | conversion to 4:2:0 - [0.127%] [avg time: 0.008 ms]
23:45:53: Convert444Threads - [100%] [avg time: 3.287 ms] [children: 99.3%] [unaccounted: 0.669%]
23:45:53: | Convert444toNV12 - [99.3%] [avg time: 3.265 ms]
23:45:53: encoder thread frame - [100%] [avg time: 10.321 ms]
23:45:53:
23:45:53:
23:45:53: Profiler CPU results:
23:45:53:
23:45:53: video thread frame - [cpu time: avg 3.342 ms, total 93.6 ms] [avg calls per frame: 1]
23:45:53: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:45:53: | GPU download and conversion - [cpu time: avg 3.342 ms, total 93.6 ms] [avg calls per frame: 1]
23:45:53: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:45:53: | | CopyResource - [cpu time: avg 7.2 ms, total 93.6 ms] [avg calls per frame: 0]
23:45:53: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 0]
23:45:53: Convert444Threads - [cpu time: avg 4.55 ms, total 109.2 ms] [avg calls per frame: 2]
23:45:53: | Convert444toNV12 - [cpu time: avg 4.55 ms, total 109.2 ms] [avg calls per frame: 2]
23:45:53: encoder thread frame - [cpu time: avg 5.672 ms, total 62.4 ms] [avg calls per frame: 1]
23:45:53:
23:45:53: =====Stream End: 2014-01-21, 23:45:53=================================================
23:46:08: =====Stream Start: 2014-01-21, 23:46:08===============================================
23:46:08: Multithreaded optimizations: On
23:46:08: Base resolution: 1680x1050
23:46:08: Output resolution: 1344x840
23:46:08: ------------------------------------------
23:46:08: Loading up D3D10 on NVIDIA GeForce 8600 GT (Adapter 1)...
23:46:08: Audio Format: 48000hz
23:46:08: Playback device Default
23:46:08: Using desktop audio input: Headphones (High Definition Audio Device)
23:46:08: Using auxilary audio input: Microphone (High Definition Audio Device)
23:46:08: Audio Encoding: AAC
23:46:08: bitrate: 128
23:46:08: Using graphics capture
23:46:08: Scene buffering time set to 400
23:46:08: Video Encoding: x264
23:46:08: fps: 30
23:46:08: width: 1344, height: 840
23:46:08: preset: veryfast
23:46:08: profile: main
23:46:08: keyint: 60
23:46:08: CBR: yes
23:46:08: CFR: yes
23:46:08: max bitrate: 2000
23:46:08: buffer size: 2000
23:46:08: MMDeviceAudioSource: Frequency for device 'Headphones (High Definition Audio Device)' is 352800, samples per sec is 44100
23:46:08: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
23:46:08: SharedTexCapture hooked
23:46:10: Using RTMP service: Twitch / Justin.tv
23:46:10: Server selection: rtmp://live-iad.justin.tv/app
23:46:10: Interface: Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) #2 (ethernet, 1000 mbps)
23:46:10: Completed handshake with rtmp://live-iad.justin.tv/app in 271 ms.
23:46:11: SO_SNDBUF was at 8192
23:46:11: SO_SNDBUF is now 65536
23:46:13: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 0 / 272384)
23:46:17: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 0 / 272384)
23:46:18: Total frames encoded: 274, total frames duplicated: 122 (44.53%)
23:46:18: Total frames rendered: 165, number of late frames: 76 (46.06%) (it's okay for some frames to be late)
23:46:18: RTMPPublisher::SocketLoop: Graceful loop exit
23:46:18: Average send payload: 6420 bytes, average send interval: 24 ms
23:46:18: Number of times waited to send: 0, Waited for a total of 0 bytes
23:46:18: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
23:46:18: Number of bytes sent: 1444688
23:46:18:
23:46:18: Profiler time results:
23:46:18:
23:46:18: ==============================================================
23:46:18: video thread frame - [100%] [avg time: 46.171 ms] [children: 95.6%] [unaccounted: 4.41%]
23:46:18: | scene->Preprocess - [0.00866%] [avg time: 0.004 ms]
23:46:18: | GPU download and conversion - [95.6%] [avg time: 44.132 ms] [children: 105%] [unaccounted: -9.87%]
23:46:18: | | flush - [0.459%] [avg time: 0.212 ms]
23:46:18: | | CopyResource - [105%] [avg time: 48.283 ms]
23:46:18: | | conversion to 4:2:0 - [0.425%] [avg time: 0.196 ms]
23:46:18: Convert444Threads - [100%] [avg time: 3.852 ms] [children: 99.1%] [unaccounted: 0.909%]
23:46:18: | Convert444toNV12 - [99.1%] [avg time: 3.817 ms]
23:46:18: encoder thread frame - [100%] [avg time: 5.154 ms]
23:46:18:
23:46:18:
23:46:18: Profiler CPU results:
23:46:18:
23:46:18: video thread frame - [cpu time: avg 8.509 ms, total 1404.01 ms] [avg calls per frame: 1]
23:46:18: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:46:18: | GPU download and conversion - [cpu time: avg 7.752 ms, total 1279.21 ms] [avg calls per frame: 1]
23:46:18: | | flush - [cpu time: avg 0.094 ms, total 15.6 ms] [avg calls per frame: 1]
23:46:18: | | CopyResource - [cpu time: avg 8.375 ms, total 1248.01 ms] [avg calls per frame: 1]
23:46:18: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:46:18: Convert444Threads - [cpu time: avg 3.162 ms, total 936.005 ms] [avg calls per frame: 2]
23:46:18: | Convert444toNV12 - [cpu time: avg 3.162 ms, total 936.005 ms] [avg calls per frame: 2]
23:46:18: encoder thread frame - [cpu time: avg 4.287 ms, total 1123.21 ms] [avg calls per frame: 1]
23:46:18:
23:46:18: =====Stream End: 2014-01-21, 23:46:18=================================================
23:46:19: =====Stream Start: 2014-01-21, 23:46:19===============================================
23:46:19: Multithreaded optimizations: On
23:46:19: Base resolution: 1680x1050
23:46:19: Output resolution: 1344x840
23:46:19: ------------------------------------------
23:46:19: Loading up D3D10 on NVIDIA GeForce 8600 GT (Adapter 1)...
23:46:19: Audio Format: 48000hz
23:46:19: Playback device Default
23:46:19: Using desktop audio input: Headphones (High Definition Audio Device)
23:46:19: Using auxilary audio input: Microphone (High Definition Audio Device)
23:46:19: Audio Encoding: AAC
23:46:19: bitrate: 128
23:46:19: Using graphics capture
23:46:19: Scene buffering time set to 400
23:46:19: Video Encoding: x264
23:46:19: fps: 30
23:46:19: width: 1344, height: 840
23:46:19: preset: veryfast
23:46:19: profile: main
23:46:19: keyint: 60
23:46:19: CBR: yes
23:46:19: CFR: yes
23:46:19: max bitrate: 2000
23:46:19: buffer size: 2000
23:46:19: MMDeviceAudioSource: Frequency for device 'Headphones (High Definition Audio Device)' is 352800, samples per sec is 44100
23:46:19: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
23:46:21: SharedTexCapture hooked
23:46:33: Total frames encoded: 392, total frames duplicated: 192 (48.98%)
23:46:33: Total frames rendered: 211, number of late frames: 118 (55.92%) (it's okay for some frames to be late)
23:46:33:
23:46:33: Profiler time results:
23:46:33:
23:46:33: ==============================================================
23:46:33: video thread frame - [100%] [avg time: 54.984 ms] [children: 96.4%] [unaccounted: 3.61%]
23:46:33: | scene->Preprocess - [0.0127%] [avg time: 0.007 ms]
23:46:33: | GPU download and conversion - [96.4%] [avg time: 52.992 ms] [children: 104%] [unaccounted: -7.23%]
23:46:33: | | flush - [0.349%] [avg time: 0.192 ms]
23:46:33: | | CopyResource - [102%] [avg time: 56.332 ms]
23:46:33: | | conversion to 4:2:0 - [0.804%] [avg time: 0.442 ms]
23:46:33: Convert444Threads - [100%] [avg time: 3.222 ms] [children: 99.3%] [unaccounted: 0.745%]
23:46:33: | Convert444toNV12 - [99.3%] [avg time: 3.198 ms]
23:46:33: encoder thread frame - [100%] [avg time: 4.39 ms]
23:46:33:
23:46:33:
23:46:33: Profiler CPU results:
23:46:33:
23:46:33: video thread frame - [cpu time: avg 9.019 ms, total 1903.21 ms] [avg calls per frame: 1]
23:46:33: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:46:33: | GPU download and conversion - [cpu time: avg 8.058 ms, total 1700.41 ms] [avg calls per frame: 1]
23:46:33: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:46:33: | | CopyResource - [cpu time: avg 8.595 ms, total 1684.81 ms] [avg calls per frame: 1]
23:46:33: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:46:33: Convert444Threads - [cpu time: avg 2.96 ms, total 1154.41 ms] [avg calls per frame: 2]
23:46:33: | Convert444toNV12 - [cpu time: avg 2.96 ms, total 1154.41 ms] [avg calls per frame: 2]
23:46:33: encoder thread frame - [cpu time: avg 3.366 ms, total 1279.21 ms] [avg calls per frame: 1]
23:46:33:
23:46:33: =====Stream End: 2014-01-21, 23:46:33=================================================
23:46:34: =====Stream Start: 2014-01-21, 23:46:34===============================================
23:46:34: Multithreaded optimizations: On
23:46:34: Base resolution: 1680x1050
23:46:34: Output resolution: 1344x840
23:46:34: ------------------------------------------
23:46:34: Loading up D3D10 on NVIDIA GeForce 8600 GT (Adapter 1)...
23:46:34: Audio Format: 48000hz
23:46:34: Playback device Default
23:46:34: Using desktop audio input: Headphones (High Definition Audio Device)
23:46:34: Using auxilary audio input: Microphone (High Definition Audio Device)
23:46:34: Audio Encoding: AAC
23:46:34: bitrate: 128
23:46:34: Using graphics capture
23:46:34: Scene buffering time set to 400
23:46:34: Video Encoding: x264
23:46:34: fps: 30
23:46:34: width: 1344, height: 840
23:46:34: preset: veryfast
23:46:34: profile: main
23:46:34: keyint: 60
23:46:34: CBR: yes
23:46:34: CFR: yes
23:46:34: max bitrate: 2000
23:46:34: buffer size: 2000
23:46:34: MMDeviceAudioSource: Frequency for device 'Headphones (High Definition Audio Device)' is 352800, samples per sec is 44100
23:46:34: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
23:46:38: Total frames encoded: 84, total frames duplicated: 0 (0.00%)
23:46:38: Total frames rendered: 90, number of late frames: 1 (1.11%) (it's okay for some frames to be late)
23:46:38:
23:46:38: Profiler time results:
23:46:38:
23:46:38: ==============================================================
23:46:38: video thread frame - [100%] [avg time: 6.869 ms] [children: 90.8%] [unaccounted: 9.19%]
23:46:38: | scene->Preprocess - [0.0291%] [avg time: 0.002 ms]
23:46:38: | GPU download and conversion - [90.8%] [avg time: 6.236 ms] [children: 110%] [unaccounted: -19%]
23:46:38: | | flush - [1.6%] [avg time: 0.11 ms]
23:46:38: | | CopyResource - [108%] [avg time: 7.422 ms]
23:46:38: | | conversion to 4:2:0 - [0.102%] [avg time: 0.007 ms]
23:46:38: Convert444Threads - [100%] [avg time: 2.592 ms] [children: 99.3%] [unaccounted: 0.694%]
23:46:38: | Convert444toNV12 - [99.3%] [avg time: 2.574 ms]
23:46:38: encoder thread frame - [100%] [avg time: 3.193 ms]
23:46:38:
23:46:38:
23:46:38: Profiler CPU results:
23:46:38:
23:46:38: video thread frame - [cpu time: avg 5.893 ms, total 530.403 ms] [avg calls per frame: 1]
23:46:38: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:46:38: | GPU download and conversion - [cpu time: avg 5.893 ms, total 530.403 ms] [avg calls per frame: 1]
23:46:38: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:46:38: | | CopyResource - [cpu time: avg 7.167 ms, total 530.403 ms] [avg calls per frame: 1]
23:46:38: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:46:38: Convert444Threads - [cpu time: avg 1.495 ms, total 218.4 ms] [avg calls per frame: 2]
23:46:38: | Convert444toNV12 - [cpu time: avg 1.495 ms, total 218.4 ms] [avg calls per frame: 2]
23:46:38: encoder thread frame - [cpu time: avg 2.6 ms, total 187.201 ms] [avg calls per frame: 1]
23:46:38:
23:46:38: =====Stream End: 2014-01-21, 23:46:38=================================================
23:46:38: =====Stream Start: 2014-01-21, 23:46:38===============================================
23:46:38: Multithreaded optimizations: On
23:46:38: Base resolution: 1680x1050
23:46:38: Output resolution: 1344x840
23:46:38: ------------------------------------------
23:46:38: Loading up D3D10 on NVIDIA GeForce 8600 GT (Adapter 1)...
23:46:38: Audio Format: 48000hz
23:46:38: Playback device Default
23:46:38: Using desktop audio input: Headphones (High Definition Audio Device)
23:46:38: Using auxilary audio input: Microphone (High Definition Audio Device)
23:46:38: Audio Encoding: AAC
23:46:38: bitrate: 128
23:46:38: Using graphics capture
23:46:38: Scene buffering time set to 400
23:46:38: Video Encoding: x264
23:46:38: fps: 30
23:46:38: width: 1344, height: 840
23:46:38: preset: veryfast
23:46:38: profile: main
23:46:38: keyint: 60
23:46:38: CBR: yes
23:46:38: CFR: yes
23:46:38: max bitrate: 2000
23:46:38: buffer size: 2000
23:46:38: MMDeviceAudioSource: Frequency for device 'Headphones (High Definition Audio Device)' is 352800, samples per sec is 44100
23:46:38: MMDeviceAudioSource: Frequency for device 'Microphone (High Definition Audio Device)' is 352800, samples per sec is 44100
23:46:40: Using RTMP service: Twitch / Justin.tv
23:46:40: Server selection: rtmp://live-iad.justin.tv/app
23:46:40: Interface: Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) #2 (ethernet, 1000 mbps)
23:46:40: Completed handshake with rtmp://live-iad.justin.tv/app in 287 ms.
23:46:40: Total frames encoded: 46, total frames duplicated: 0 (0.00%)
23:46:40: Total frames rendered: 52, number of late frames: 1 (1.92%) (it's okay for some frames to be late)
23:46:41: SO_SNDBUF was at 8192
23:46:41: SO_SNDBUF is now 65536
23:46:41: RTMPPublisher::SocketLoop: Graceful loop exit
23:46:41: Number of times waited to send: 0, Waited for a total of 0 bytes
23:46:41: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
23:46:41: Number of bytes sent: 0
23:46:41:
23:46:41: Profiler time results:
23:46:41:
23:46:41: ==============================================================
23:46:41: video thread frame - [100%] [avg time: 5.841 ms] [children: 90.5%] [unaccounted: 9.48%]
23:46:41: | scene->Preprocess - [0.0342%] [avg time: 0.002 ms]
23:46:41: | GPU download and conversion - [90.5%] [avg time: 5.285 ms] [children: 128%] [unaccounted: -37.9%]
23:46:41: | | flush - [1.99%] [avg time: 0.116 ms]
23:46:41: | | CopyResource - [126%] [avg time: 7.373 ms]
23:46:41: | | conversion to 4:2:0 - [0.12%] [avg time: 0.007 ms]
23:46:41: Convert444Threads - [100%] [avg time: 2.698 ms] [children: 99.2%] [unaccounted: 0.815%]
23:46:41: | Convert444toNV12 - [99.2%] [avg time: 2.676 ms]
23:46:41: encoder thread frame - [100%] [avg time: 1.944 ms]
23:46:41:
23:46:41:
23:46:41: Profiler CPU results:
23:46:41:
23:46:41: video thread frame - [cpu time: avg 4.2 ms, total 218.401 ms] [avg calls per frame: 1]
23:46:41: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:46:41: | GPU download and conversion - [cpu time: avg 4.2 ms, total 218.401 ms] [avg calls per frame: 1]
23:46:41: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:46:41: | | CopyResource - [cpu time: avg 6.066 ms, total 218.401 ms] [avg calls per frame: 1]
23:46:41: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
23:46:41: Convert444Threads - [cpu time: avg 2.674 ms, total 187.2 ms] [avg calls per frame: 2]
23:46:41: | Convert444toNV12 - [cpu time: avg 2.674 ms, total 187.2 ms] [avg calls per frame: 2]
23:46:41: encoder thread frame - [cpu time: avg 1.835 ms, total 62.4 ms] [avg calls per frame: 1]
23:46:41:
23:46:41: =====Stream End: 2014-01-21, 23:46:41=================================================
What I tried:
Changing the Bitrate up to 3300 and down to 1000, no change either way.
Increasing the downscale amount (already at 1.25) to 2.0. No change.
Changing the downscaling filter up and down. No change. Didn't expect one.
Changing the scene buffering time up to 700ms. Grasping at straws here.
Changing the x264 CPU Preset up to Superfast and Ultrafast. No change.
Changing the Encoding profile from main to high. No change.
I am already using Game Capture (Googling, not using Game Capture seemed to be most peoples problem).
There are a LOT more buttons here that I could push, but I could use some direction.
Sapiens
Forum Moderator
A Q6600 CPU and an 8600GT GPU are not going to cut it for streaming at those settings. Hearthstone is something of an exception because there's very little going on, but WoT is a different animal. You're going to need to downscale a lot, and you may need to use a less demanding preset as well. I would start with a 2.5 downscale (672x420) on the superfast preset and see if there's any change. If your hardware is already strained by running the game then streaming may not be viable.
Volatar
Even if settings that low did work I wouldn't be happy with them.
No WoT streaming from this rig it is then. Thank you.
