AlexanderHarizanov
so i am switching from Xsplit Broadcaster to OBS Studio 19.0.2 to test NDI but my 1st issue now is:
i have 2x Logitec C922 Pro Streamer webcams and when i add 2 video sources to the scene only the 1st one works.
i can switch on the 1st source between both the cameras but when i try to add both of them the 2nd one does not manage to turn the cam itself.
I have tried closing LGS, Skype, etc.
drivers are installed sense the 1st source can switch between both cams fine.
i need some help :P
Scene Item Transformation when adding the 2nd cam glitches cause it cant enable the cam and shows:
Size: 90001.0000 90001.0000
2nd issue ...
while testing NDI 30/30 60/60 30/60 streams (1st is the gaming 2nd is the encoding OBS/Xsplit)
so i tested a few things.
Xsplit Broadcaster 3.0 > Xsplit Broadcaster 3.0 there was heavy picture freezing on the encoding PC side (that is even on the XBC display panel with no actual encoding/recording being done) dou its the same with encoding
OBS Studio > XBC same result
OBS Studio > OBS Studio no issues with the video both on 30/30 and 60/60 fps but audio was crap and maxing the CPU encoding at 85% on medium the quality wasnt that nice after the encoding/recordings were tested
XBC > OBS Studio no audio issues no video issues but still recording/stream quality being maxed to the CPU at 85% load was still heavy pixelization.
i did try to play with OBS Studio audio settings but with no luck to fix the audio issue that seems to be coming from the NDI or Audio settings on the gaming PC Studio
also no that relevant info is OBS is giving me x2 CSGO fps while the NDI is running compared to XBC
best case for me would be OBS Studio NDI on the gaming PC with fixed audio + XBC if the idiots finally fix the video freezes that it receives on the Encoding PC considering the quality of the video is better.
sorry for the big post and please dont be offended by my conclusions so far.
any help is much appreciated.
i need some help :P
2nd issue ...
