Question / Help 2 C920 cameras, Blue Yeti pro problem
Jose Fernandez
Hi, I've spent about 3 days on this and I 100% located the problem after trial & error for ages.
Apparently, I cannot have 2 Logitech C920 cameras in one scene, if I disable one, my Blue Yeti Pro works perfectly, if I enable the second one it starts to stutter and cut off in a 5-8 seconds loop, does anyone have a solution to this? or work around?
Thanks in advance!
JD
dodgepong
Administrator
Community Helper
Sounds like an issue with USB saturation (too much data using up all your USB bandwidth). Try lowering the resolution of the webcams, and do your best to try to use different USB controllers for each input, if possible. That may be tough if you're on a laptop though.
Jose Fernandez
How come it works when using the headset though? Is it because the Yeti Pro uses more bandwidth than the wireless headset?
P.S: I'm using an ASUS X99-Deluxe and a 5930k, I'll try using different USB controllers.
Thanks for the reply!
