2.50 mbps Upload speed settings
demy1942
Hi,
I did look around a little bit and I have a 2.50 upload speed. While streaming, I am using the 1920x1080 and was using my tablet to monitor the stream from the youtube channel. It used to be smooth but now the stream stops and starts every 10-15 seconds. I need to get the fiber optic in the home but until then,......
Bit rate - 3000-4500
scaled was 1920x1080 going to try 1280x720
I did the auto wizard and it wanted a resolution of 800x? cant remember number
any suggestions? Some of this stuff is not in my wheelhouse but learning.
Thanks
I would stick with 1024x720 30 FPS or less. I think YouTube will downscale resolutions between 1080 and 720 to 720. Depending on your content you may be able to get away with 1080. Static content such as a border can help.
