Question / Help 1080p stream / 4K recording - system questions
psnorton23
I need a PC system that will allow me to stream 1080p and record in 4K
I will use 3 cameras at the same time.
The OBS canvas will be 4K.
The additional camera angles will be available as small feeds in the corner (like a let's play).
Everything will need to be new as no part of my current system will keep up...
I do have 2 Cam Link 4K units though.
So if those can be reused that would help.
For the system I would need, I'm not really sure where to put the focus or if I just need to overpower everything.
I'm NOT playing any games, only recording/streaming video for a show.
I'm OK with building a system, but if there is an existing build from a custom PC maker I'm OK with paying extra for it to just work and no headaches.
Does anyone have an suggestions on where I should start?
Tomasz Góral
For 3 cameras i use i7-6700, as source use two GC553 and blackmagic mini recorder 4k (all card grab 4k25).
As you can see this is not the latest model, I recently bought a laptop that is about 25% faster (i7-9750 HP Omen).
psnorton23
What are your settings for quality in OBS? 30FPS?
I recommend you adding an NVIDIA 1650 SUPER or better to use the NVENC encoder.
What level of quality @ 30FPS would I be able to record with a 1650 Super? Medium?
BigYuckFou
i agree to stream at 1080p and record at 4k is going to be intensive on many PCs. pretty certain I would struggle to do it and I get a beast of a PC.
side note for $350 you can gt the EVGA 2060 KO or KO Ultra that has the TU104 chip the same as the 1080.. but with less cuda cores. but the encoding chip is the same and on the larger die too.
If you want to stream and record you are going to either need to stream using the CPU and or GPU, then in your case due to different resolutions need to use the other to record. so stream with the CPU since 1080 is less intensive and record at 4k using your GPU.
you are probably going to be able to stream and record medium quality.
Here is my PC beast that would struggle to do 4 k record and 1080p stream at slow quality.
psnorton23
So a 1080 would be able to handle the 4K with 3 camera sources?
Or would the additional camera sources require a better GPU?
Would I see a benefit from going to a 20XX card?
On the CPU, better to go with something that has more cores? Like a Threadripper?
BigYuckFou
if you attempting to do all encoding on your GPU then the 1650 super or higher they are all the same encoding chip, some things like look ahead and physco visual tuning do use cuda cores. so i would get an evga 2016 KO
if you plan to use the CPU to encode medium just about any 4ghz 8 core will do. try encoding at slow and your going to need at least 12 ores. IMO.
psnorton23
So if I am encoding using the GPU for the 4K like you suggested, there is no benefit for me to go to something like a (just for example) 2080ti 11gb card instead of the evga 2016 KO because they all use the same encoding chip?
If I used the CPU for encoding the 4K recording I want a minimum of 12 cores .... is that with the GPU doing the 1080p streaming?
Or am I misunderstanding how things work?
I'm not aiming for medium, that was just me wondering what I could get done with x parts.
Tomasz Góral
Nvidia 10xx and 1650 have the same encoding chipset, 1660 and 20xx are the same chip.
I have 3 camera on i7-6700 Nvidia 1050Ti, 1080p50 or 4kp25, in first case CPU <50%, in second CPU <70%.
My CPU is water cooled.
rockbottom
I have a 6700k along with a GTX-1660 Super, my set-up can do everything you're asking for & much more!
I was actually going to build a new system when the Ryzen 9's came out but decided to swap out my Fury X with the 1660 Super. Now, I have absolutely no need to do anything as my system smokes.
If I was to build a new system right now, it would be with a 3900X or 3950X & an RTX-2080ti.
What NLE are you using? Vegas Pro 17 is GPU accelerated but with the Voukoder encoder rendering speeds are absolutely insane when using NVENC.
Would I see any improvement when editing recordings with a 2060 over a 1660?
Nope
psnorton23
I have Adobe Premiere.
I'm kind of sick of paying for it but it's what I know so...
What do you do that the 2080ti would benefit you over the 1660?
When I say improvement I don't mean in the actual recording ... I mean would a 2060 do the work faster than a 1660?
psnorton23
Thanks I will check that out!
I am thinking a Ryzen 9 3950x and a 1660 card.
To maximize the 4K recording, will I end up wanting to to use the CPU there and the GPU for the 1080p stream (which is downscaled from the 4K canvas)?
That is my hope but I just want to make sure the GPU can tolerate that.
My focus is the 4K but I don't want the stream to look like garbage.
rockbottom
Gotcha!
Do what I did, throw the 1660 in your current system & test it out. If you decide that you want to use x264 instead for your 4k recording, just move it to your new system. I think you'll be surprised how good the Turing encoder is.
psnorton23
When you say instead .... are you meaning use the GPU for both the stream and recording?
I am streaming 1080 and recording 4K at the same time. (I forgot to note that in the first post)
I didn't think the GPU would tolerate that and someone had said that since I am recording in one resolution and streaming in another I'd have to split the work.
It actually would not fit in the system I currently have anyway. It's a little Dell 3420 tower that only has a single slot available because of the pci wifi card I had to add.
psnorton23
From what I am reading/seeing .... if I want to use the new NVENC in OBS, I can't rescale the output down from 4K to 1080p. I'd have to use the old NVENC. So I would have to use the GPU for 4K recording and the x264 to rescale down to 1080p. I'm not sure how this will impact everything.
rockbottom
Take a look, there will be multiple posts
19:05:58.526: CoInitializeEx succeeded: 0x00000001
19:05:58.526: CPU Name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
19:05:58.526: CPU Speed: 4008MHz
19:05:58.526: Physical Cores: 4, Logical Cores: 8
19:05:58.526: Physical Memory: 32720MB Total, 21198MB Free
19:05:58.526: Windows Version: 10.0 Build 18362 (release: 1903; revision: 720; 64-bit)
19:05:58.526: Running as administrator: false
19:05:58.527: Aero is Enabled (Aero is always on for windows 8 and above)
19:05:58.527: Windows 10 Gaming Features:
19:05:58.527: Game Bar: Off
19:05:58.527: Game DVR: Off
19:05:58.527: Game DVR Background Recording: Off
19:05:58.527: Game Mode: Off
19:05:58.528: Sec. Software Status:
19:05:58.530: Windows Defender Antivirus: enabled (AV)
19:05:58.530: Windows Firewall: enabled (FW)
19:05:58.530: Current Date/Time: 2020-05-27, 19:05:58
19:05:58.530: Browser Hardware Acceleration: false
19:05:58.530: Portable mode: false
19:05:58.778: OBS 25.0.8 (64-bit, windows)
19:05:58.778: ---------------------------------
19:05:58.779: ---------------------------------
19:05:58.779: audio settings reset:
19:05:58.779: samples per sec: 48000
19:05:58.779: speakers: 2
19:05:58.780: ---------------------------------
19:05:58.780: Initializing D3D11...
19:05:58.780: Available Video Adapters:
19:05:58.782: Adapter 0: NVIDIA GeForce GTX 1660 SUPER
19:05:58.782: Dedicated VRAM: 1987051520
19:05:58.782: Shared VRAM: 4269969408
19:05:58.782: PCI ID: 10de:21c4
19:05:58.782: Driver Version: 26.21.14.4587
19:05:58.782: output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=60, name=ASUS VG236
19:05:58.782: output 1: pos={1920, 0}, size={1920, 1080}, attached=true, refresh=60, name=AVM 50v
19:05:58.783: Loading up D3D11 on adapter NVIDIA GeForce GTX 1660 SUPER (0)
19:05:58.820: D3D11 loaded successfully, feature level used: b000
19:05:58.820: DXGI increase maximum frame latency success
19:05:58.820: D3D11 GPU priority setup failed (not admin?)
19:05:59.156: ---------------------------------
19:05:59.157: video settings reset:
19:05:59.157: base resolution: 3840x2160
19:05:59.157: output resolution: 3840x2160
19:05:59.157: downscale filter: Bicubic
19:05:59.157: fps: 60/1
19:05:59.157: format: NV12
19:05:59.157: YUV mode: 709/Partial
19:05:59.157: NV12 texture support enabled
19:05:59.158: Audio monitoring device:
19:05:59.158: name: Default
19:05:59.158: id: default
19:05:59.158: ---------------------------------
19:05:59.163: [CoreAudio encoder]: Adding CoreAudio AAC encoder
19:05:59.163: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
19:05:59.185: [AMF] Unable to load 'amfrt64.dll', error code 126.
19:05:59.187: [AMF] AMF Test failed due to one or more errors.
19:05:59.187: Failed to initialize module 'enc-amf.dll'
19:05:59.201: [obs-browser]: Version 2.8.6
19:05:59.205: NVENC supported
19:05:59.206: [obs-ndi] hello ! (version 4.9.0)
19:05:59.206: [obs-ndi] Trying 'C:\Program Files\NewTek\NDI 4 Tools\Runtime'
19:05:59.206: [obs-ndi] Found NDI library at 'C:/Program Files/NewTek/NDI 4 Tools/Runtime/Processing.NDI.Lib.x64.dll'
19:05:59.209: [obs-ndi] NDI runtime loaded successfully
19:05:59.214: [obs-ndi] NDI library initialized successfully (NDI SDK WIN64 03:35:12 Mar 25 2020 4.5.0.0)
19:05:59.307: VLC found, VLC video source enabled
19:05:59.313: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
19:05:59.314: No blackmagic support
19:05:59.318: ---------------------------------
19:05:59.318: Loaded Modules:
19:05:59.318: win-wasapi.dll
19:05:59.318: win-mf.dll
19:05:59.318: win-dshow.dll
19:05:59.318: win-decklink.dll
19:05:59.318: win-capture.dll
19:05:59.318: vlc-video.dll
19:05:59.318: text-freetype2.dll
19:05:59.318: rtmp-services.dll
19:05:59.318: obs-x264.dll
19:05:59.318: obs-vst.dll
19:05:59.318: obs-transitions.dll
19:05:59.318: obs-text.dll
19:05:59.318: obs-qsv11.dll
19:05:59.318: obs-outputs.dll
19:05:59.318: obs-ndi.dll
19:05:59.318: obs-filters.dll
19:05:59.318: obs-ffmpeg.dll
19:05:59.318: obs-ffmpeg-encoder.dll
19:05:59.318: obs-browser.dll
19:05:59.318: image-source.dll
19:05:59.318: frontend-tools.dll
19:05:59.318: enc-amf.dll
19:05:59.318: decklink-ouput-ui.dll
19:05:59.318: coreaudio-encoder.dll
19:05:59.318: ==== Startup complete ===============================================
19:05:59.325: All scene data cleared
19:05:59.325: ------------------------------------------------
19:05:59.357: WASAPI: Device 'Speakers (2- ASUS Xonar Essence STX Audio Device)' [96000 Hz] initialized
19:05:59.357: [Loaded global audio device]: 'Desktop Audio'
19:05:59.419: [window-capture: 'Window Capture 2'] update settings:
19:05:59.419: executable: chrome.exe
19:05:59.421: [window-capture: 'Window Capture'] update settings:
19:05:59.421: executable: firefox.exe
19:05:59.762: Switched to scene 'Asus GTX-1660 Super Advanced'
19:05:59.762: ------------------------------------------------
19:05:59.762: Loaded scenes:
19:05:59.762: - scene 'Asus GTX-1660 Super Advanced':
19:05:59.762: - source: 'TRI East Image A' (image_source)
19:05:59.762: - source: 'Asus GTX-1660 Super To D2v' (monitor_capture)
19:05:59.762: - scene 'TRI-East 1':
19:05:59.762: - source: 'VLC Video Source' (vlc_source)
19:05:59.762: - scene 'TRI-East 2':
19:05:59.762: - source: 'VLC Video Source 2' (vlc_source)
19:05:59.762: - scene 'TRI-East 3':
19:05:59.762: - source: 'VLC Video Source 3' (vlc_source)
19:05:59.762: - scene 'TRI-East 4':
19:05:59.762: - scene 'Stealie':
19:05:59.762: - source: 'Image' (image_source)
19:05:59.762: - scene 'Stay Tuned':
19:05:59.762: - source: 'Stay Tuned Image A' (image_source)
19:05:59.762: - scene 'Test Screen Slide Show':
19:05:59.762: - source: 'Image Slide Show' (slideshow)
19:05:59.762: - scene 'Firefox - Window':
19:05:59.762: - source: 'Window Capture' (window_capture)
19:05:59.762: - scene 'Chrome - Window':
19:05:59.762: - source: 'Window Capture 2' (window_capture)
19:05:59.762: - scene 'Fade To Black':
19:05:59.762: - source: 'Color Source' (color_source)
rockbottom
19:07:56.538: User switched to scene 'TRI-East 1'
19:09:22.265: User switched to scene 'Asus GTX-1660 Super Advanced'
19:10:46.171: [jim-nvenc: 'streaming_h264'] scaling enabled, falling back to ffmpeg
19:10:46.171: ---------------------------------
19:10:46.171: [NVENC encoder: 'streaming_h264'] settings:
19:10:46.171: rate_control: CBR
19:10:46.171: bitrate: 8200
19:10:46.171: cqp: 0
19:10:46.171: keyint: 120
19:10:46.171: preset: hq
19:10:46.171: profile: high
19:10:46.171: width: 1920
19:10:46.171: height: 1080
19:10:46.171: 2-pass: true
19:10:46.171: b-frames: 2
19:10:46.171: GPU: 0
19:10:46.171:
19:10:46.304: [CoreAudio AAC: 'avc_aac_stream']: settings:
19:10:46.304: mode: AAC
19:10:46.304: bitrate: 320
19:10:46.304: sample rate: 48000
19:10:46.304: cbr: on
19:10:46.304: output buffer: 1536
19:10:46.305: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://127.0.0.1...
19:10:46.305: No application or playpath in URL!
19:10:46.306: [rtmp stream: 'adv_stream'] Interface: Software Loopback Interface 1 (type 24, 1073 mbps)
19:10:48.068: [rtmp stream: 'adv_stream'] Connection to rtmp://127.0.0.1 successful
19:10:48.071: ==== Streaming Start ===============================================
19:11:06.016: [jim-nvenc: 'recording_h264'] settings:
19:11:06.016: rate_control: CQP
19:11:06.016: bitrate: 0
19:11:06.016: cqp: 18
19:11:06.016: keyint: 120
19:11:06.016: preset: mq
19:11:06.016: profile: high
19:11:06.016: width: 3840
19:11:06.016: height: 2160
19:11:06.016: 2-pass: true
19:11:06.016: b-frames: 2
19:11:06.016: lookahead: true
19:11:06.016: psycho_aq: true
19:11:06.016:
19:11:06.094: [CoreAudio AAC: 'Track1']: settings:
19:11:06.094: mode: AAC
19:11:06.094: bitrate: 320
19:11:06.094: sample rate: 48000
19:11:06.094: cbr: on
19:11:06.094: output buffer: 1536
19:11:06.096: ==== Recording Start ===============================================
19:11:06.096: [ffmpeg muxer: 'adv_file_output'] Writing file 'K:/NVENC HQ FRAME DROP TEST/2020-05-27_19-11-05.mp4'...
19:11:13.595: User switched to scene 'TRI-East 1'
19:11:13.670: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: VLC Video Source)
19:11:13.670:
19:15:19.695: [ffmpeg muxer: 'adv_file_output'] Output of file 'K:/NVENC HQ FRAME DROP TEST/2020-05-27_19-11-05.mp4' stopped
19:15:19.695: Output 'adv_file_output': stopping
19:15:19.695: Output 'adv_file_output': Total frames output: 15199
19:15:19.695: Output 'adv_file_output': Total drawn frames: 15216
19:15:19.696: ==== Recording Stop ================================================
19:15:26.712: [rtmp stream: 'adv_stream'] User stopped the stream
19:15:26.712: Output 'adv_stream': stopping
19:15:26.712: Output 'adv_stream': Total frames output: 16705
19:15:26.712: Output 'adv_stream': Total drawn frames: 16824
19:15:26.715: ==== Streaming Stop ================================================
19:15:30.713: User switched to scene 'Asus GTX-1660 Super Advanced'
19:15:39.601: ==== Shutting down ==================================================
19:15:39.608: Switched to scene '(null)'
19:15:39.621: WASAPI: Device 'Speakers (2- ASUS Xonar Essence STX Audio Device)' Terminated
19:15:39.627: All scene data cleared
19:15:39.627: ------------------------------------------------
19:15:39.701: Freeing OBS context data
19:15:39.727: [obs-ndi] goodbye !
19:15:39.730: [Scripting] Total detached callbacks: 0
19:15:39.738: == Profiler Results =============================
19:15:39.738: run_program_init: 1428.63 ms
19:15:39.738: ┣OBSApp::AppInit: 15.462 ms
19:15:39.738: ┃ ┗OBSApp::InitLocale: 0.86 ms
19:15:39.738: ┗OBSApp::OBSInit: 1348.14 ms
19:15:39.738: ┣obs_startup: 3.739 ms
19:15:39.738: ┗OBSBasic::OBSInit: 1096.14 ms
19:15:39.738: ┣OBSBasic::InitBasicConfig: 0.36 ms
19:15:39.738: ┣OBSBasic::ResetAudio: 0.134 ms
19:15:39.738: ┣OBSBasic::ResetVideo: 378.757 ms
19:15:39.738: ┣OBSBasic::InitOBSCallbacks: 0.004 ms
19:15:39.738: ┣OBSBasic::InitHotkeys: 0.03 ms
19:15:39.738: ┣obs_load_all_modules: 160.139 ms
19:15:39.738: ┃ ┣obs_init_module(coreaudio-encoder.dll): 3.661 ms
19:15:39.738: ┃ ┣obs_init_module(decklink-ouput-ui.dll): 0.294 ms
19:15:39.738: ┃ ┣obs_init_module(enc-amf.dll): 22.745 ms
19:15:39.738: ┃ ┣obs_init_module(frontend-tools.dll): 3.497 ms
19:15:39.738: ┃ ┣obs_init_module(image-source.dll): 0.005 ms
19:15:39.738: ┃ ┣obs_init_module(obs-browser.dll): 0.35 ms
19:15:39.738: ┃ ┣obs_init_module(obs-ffmpeg-encoder.dll): 0.808 ms
19:15:39.738: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.56 ms
19:15:39.738: ┃ ┃ ┗nvenc_check: 0.533 ms
19:15:39.738: ┃ ┣obs_init_module(obs-filters.dll): 0.033 ms
19:15:39.738: ┃ ┣obs_init_module(obs-ndi.dll): 21.192 ms
19:15:39.738: ┃ ┣obs_init_module(obs-outputs.dll): 0.007 ms
19:15:39.738: ┃ ┣obs_init_module(obs-qsv11.dll): 72.023 ms
19:15:39.738: ┃ ┣obs_init_module(obs-text.dll): 0.155 ms
19:15:39.738: ┃ ┣obs_init_module(obs-transitions.dll): 0.006 ms
19:15:39.738: ┃ ┣obs_init_module(obs-vst.dll): 0.001 ms
19:15:39.738: ┃ ┣obs_init_module(obs-x264.dll): 0.003 ms
19:15:39.738: ┃ ┣obs_init_module(rtmp-services.dll): 0.818 ms
19:15:39.738: ┃ ┣obs_init_module(text-freetype2.dll): 0.046 ms
19:15:39.738: ┃ ┣obs_init_module(vlc-video.dll): 1.048 ms
19:15:39.738: ┃ ┣obs_init_module(win-capture.dll): 1.323 ms
19:15:39.738: ┃ ┣obs_init_module(win-decklink.dll): 4.817 ms
19:15:39.738: ┃ ┣obs_init_module(win-dshow.dll): 2.208 ms
19:15:39.738: ┃ ┣obs_init_module(win-mf.dll): 0 ms
19:15:39.738: ┃ ┣obs_init_module(win-wasapi.dll): 0.004 ms
19:15:39.738: ┃ ┗reset_win32_symbol_paths: 0.054 ms
19:15:39.738: ┣OBSBasic::ResetOutputs: 5.931 ms
19:15:39.738: ┣OBSBasic::CreateHotkeys: 0.025 ms
19:15:39.738: ┣OBSBasic::InitService: 0.103 ms
19:15:39.738: ┣OBSBasic::InitPrimitives: 0.061 ms
19:15:39.738: ┗OBSBasic::Load: 439.477 ms
19:15:39.738: obs_hotkey_thread(25 ms): min=0.003 ms, median=0.006 ms, max=2.377 ms, 99th percentile=0.067 ms, 100% below 25 ms
19:15:39.738: audio_thread(Audio): min=0 ms, median=0.054 ms, max=5.754 ms, 99th percentile=1.295 ms
19:15:39.738: ┗receive_audio: min=0.002 ms, median=0.336 ms, max=5.1 ms, 99th percentile=0.689 ms, 0.903621 calls per parent call
19:15:39.738: ┣buffer_audio: min=0 ms, median=0 ms, max=0.116 ms, 99th percentile=0.002 ms
19:15:39.738: ┗do_encode: min=0.08 ms, median=0.334 ms, max=5.095 ms, 99th percentile=0.684 ms
19:15:39.738: ┣encode(avc_aac_stream): min=0.078 ms, median=0.287 ms, max=1.452 ms, 99th percentile=0.607 ms, 0.523401 calls per parent call
19:15:39.738: ┗encode(Track1): min=0.112 ms, median=0.32 ms, max=1.689 ms, 99th percentile=0.639 ms, 0.476599 calls per parent call
19:15:39.738: obs_graphics_thread(16.6667 ms): min=0.063 ms, median=0.62 ms, max=398.2 ms, 99th percentile=2.832 ms, 99.9885% below 16.667 ms
19:15:39.738: ┣tick_sources: min=0.001 ms, median=0.02 ms, max=398.078 ms, 99th percentile=0.299 ms
19:15:39.738: ┣output_frame: min=0.044 ms, median=0.392 ms, max=7.903 ms, 99th percentile=2.478 ms
19:15:39.738: ┃ ┣gs_context(video->graphics): min=0.044 ms, median=0.319 ms, max=5.043 ms, 99th percentile=0.722 ms
19:15:39.738: ┃ ┃ ┣render_video: min=0.003 ms, median=0.261 ms, max=4.822 ms, 99th percentile=0.679 ms
19:15:39.738: ┃ ┃ ┃ ┣render_main_texture: min=0.002 ms, median=0.245 ms, max=4.819 ms, 99th percentile=0.512 ms
19:15:39.738: ┃ ┃ ┃ ┣render_convert_texture: min=0.005 ms, median=0.009 ms, max=0.121 ms, 99th percentile=0.018 ms, 0.480306 calls per parent call
19:15:39.738: ┃ ┃ ┃ ┣stage_output_texture: min=0.001 ms, median=0.002 ms, max=0.082 ms, 99th percentile=0.004 ms, 0.480306 calls per parent call
19:15:39.738: ┃ ┃ ┃ ┗output_gpu_encoders: min=0 ms, median=0.042 ms, max=0.301 ms, 99th percentile=0.08 ms, 0.437153 calls per parent call
19:15:39.738: ┃ ┃ ┣gs_flush: min=0.021 ms, median=0.041 ms, max=3.539 ms, 99th percentile=0.116 ms
19:15:39.738: ┃ ┃ ┗download_frame: min=0 ms, median=0.001 ms, max=0.025 ms, 99th percentile=0.003 ms, 0.480306 calls per parent call
19:15:39.738: ┃ ┗output_video_data: min=0.916 ms, median=1.16 ms, max=5.044 ms, 99th percentile=2.134 ms, 0.480277 calls per parent call
19:15:39.738: ┗render_displays: min=0 ms, median=0.133 ms, max=4.58 ms, 99th percentile=0.366 ms
19:15:39.738: video_thread(video): min=5.237 ms, median=5.913 ms, max=18.491 ms, 99th percentile=9.402 ms
19:15:39.738: ┗receive_video: min=0.545 ms, median=0.788 ms, max=2.568 ms, 99th percentile=1.387 ms
19:15:39.738: ┗do_encode: min=0.545 ms, median=0.787 ms, max=2.567 ms, 99th percentile=1.386 ms
19:15:39.738: ┗encode(streaming_h264): min=0.544 ms, median=0.773 ms, max=2.547 ms, 99th percentile=1.366 ms
19:15:39.738: =================================================
19:15:39.738: == Profiler Time Between Calls ==================
19:15:39.738: obs_hotkey_thread(25 ms): min=24.96 ms, median=25.93 ms, max=37.902 ms, 4.83684% within ±2% of 25 ms (0% lower, 95.1632% higher)
19:15:39.738: obs_graphics_thread(16.6667 ms): min=1.318 ms, median=16.667 ms, max=398.206 ms, 99.9282% within ±2% of 16.667 ms (0.0344768% lower, 0.0373499% higher)
19:15:39.800: Number of memory leaks: 0
