| Windows | macOS | Linux |
| ✅ Available | ✅ Available | ✅ Available |
The Noise Gate allows you to cut off all background noise while you are not talking. Select a close threshold above the noise volume and an open threshold slightly below your voice input to get good results.
| Property | Description | Default |
| Close Threshold | -32.00 dB | |
| Open Threshold | -26.00 dB | |
| Attack Time | 25 ms | |
| Hold Time | 200 ms | |
| Release Time | 150 ms |
