DigIntoGaming
I have a zoom UAC 232 audio interface capable of 32 bit floating point audio recording. I am using a rode nt1 5th generation microphone with it. When I record a 32 bit float file in reaper it is perfectly editable in davinci resolve. I can take a very badly clipping recording and restore it by reducing its volume (gain,levels whatever), like you should be able to do with 32 bit float. However if I record via OBS with FFMPEG PCM (32 bit float) audio output settings it cannot be restored in davinci resolve. It is permanently clipped and cannot be fixed like a 32 bit float audio file should be. Even more interesting, I can send audio from reaper into obs via VST plugin and record through OBS and it DOES work as a 32 bit float audio recording should in davinci resolve. So what is happening here?
I am using the UAC 232 mix control software.
I do have the UAC 232 driver installed and set to 32 bit float format.
I cannot set it to 32 bit in sound control panel via windows because it is not select able aka grayed out.
This is my first time posting to the OBS forum, and I am not great at posting to forums in general so please forgive me.
