Will not load with Razer Ripsaw plugged in
hutber
Checking if the capture device is detected
hutber@hutber:~$ v4l2-ctl --list-devices
    Razer Ripsaw X: Razer Ripsaw X (usb-0000:00:14.0-6.2):
        /dev/video0
        /dev/video1
I also have a camlink that works:
    Cam Link 4K: Cam Link 4K (usb-0000:00:14.0-6.1):
        /dev/video0
        /dev/video1
OBS output
info: v4l2-input: Start capture from
    error: v4l2-input: Unable to open device
    error: v4l2-input: Initialization failed, errno: No such file or directory
    info: xshm-input: Geometry 2560x1440 @ 2560,0
    [png_pipe @ 0x556b01ddb000] Stream #0: not enough frames to estimate rate; consider increasing probesize
    info: adding 64 milliseconds of audio buffering, total audio buffering is now 64 milliseconds (source: Mic/Aux)
    info: xshm-input: Geometry 2560x1440 @ 5120,0
    info: xshm-input: Geometry 2560x1440 @ 0,0
    info: v4l2-input: Start capture from /dev/video2
    info: v4l2-input: Start capture from /dev/video0
    info: v4l2-input: Input: 0
    info: v4l2-input: Resolution: 3840x2160
    info: v4l2-input: Pixelformat: YU12
    info: v4l2-input: Linesize: 3840 Bytes
    info: v4l2-input: Framerate: 30.00 fps
    info: v4l2-input: /dev/video0: select timeout set to 166666 (5x frame periods)
    info: alsa-input: PCM 'default' rate set to 44100
    info: alsa-input: PCM 'default' channels set to 2
    Segmentation fault (core dumped)
Of course without the ripsaw being plugged in, OBS opens and works perfectly. But I am not completely stuck in my understanding as to why it doesn't work.
I am not sure if this will help anybody else but, after playing around allot with the settings.ini I realised this won't help me at all however I did get the video working by deleting the .config/obs-studio folder which made me realise it must be the settings saved for the cameras.
As I did not want to lose all my OBS structure I deleted every camera in each scene, reset OBS and added a camera again.. and it worked.
