Hello all,
I'm using the Behringer UMC404HD to take audio from two venues, and I would like to be able to easily switch from one to the other in OBS. OBS recognizes the Behringer as audio source options like this:
Behringer UMC404 1-2
Behringer UMC404 3-4
Behringer UMC404 1-4
If I set a source with the 1-2 or 3-4 options -- which would be 1-2 coming from one venue, 3-4 from the other -- the input meter shows a steady -40dB level noise (sounds like holding your ear to a seashell). BUT if I use the 1-4 option it sounds fine, though I'm getting audio from both rooms at the same time. I downloaded the latest AISO but nothing changed.
I created a log file - https://obsproject.com/logs/vv4shaGY9xrCcVcz
Thanks for any advice!
