Poketon96
So I've had this issue that might be a little complicated to explain, so I hope I can get this across. When I play Switch games, I use my Elgato capture card and play off of OBS's source projector and enable output and monitor for it so I can listen to the game. My issue is that the audio being output from my speakers is pretty low, and I don't want to increase it any further as the audio is perfect for the stream. This isn't a problem when playing PC games as I don't have to set OBS to monitor that game's audio, but when I use my capture card, I can't find a solution to this. Of course OBS's volume level on volume mixer are at 100% as well. Playing off of source projector seems to be my only choice unless I sacrifice one of my monitors to use as the capture card's output display which would be very inconvenient to me. Thanks!
