Shenonator
Hello Guys,
if got an issue for quite some time and its did mes up some of my recordings so i thought i just ask maybe someone got the same issue or there is a known workaround for it.
Its basically, that i've set the games that i play on the Windows audío settings to play the audio on the virtual audio cable, and in obs i set this to the recorded audio, that works just fine but everytime i close the game and open it up again obs gains no audio anymore, so i just go to the windows sound manager again, set the outpout to something else and then back to the audio cable, and then it works for some reason, but if i forget that i literally record no audio even all settings are right.
is there a workaround or a fix for that?
Greets Shenonator
Greets Shenonator
