Hi everyone,
I'm using the following setup:
Video Capture Card: Elgato HD60S+
USB Microphone: HyperX SoloCast
Webcam: Logitech c922 Pro Stream
The problem is that I'm not able to use the microphone when the HD60S+ is connected to the laptop. If I go to Windows 10 Sound Settings I can see a "Digital Audio Interface" for the HD60S+ in the Recordings tab, but I'm unable to see the microphone, it doesn't appear in the list. If I disconnect the HD60S+ and then re-connect the microphone Windows detects it and I can finally see the microphone in the list under the Recordings tab. If after doind this I try to connect the HD60S+ then I'm unable to see the "Digital Audio Interface" in the Recordings list. So, I have to choose between listening to the audio from the capture card or using my USB microphone. This is a very strange issue because there are sometimes when both get detected by Windows withou any issue, this usually happends after I restart the laptop and at very random times.
Does anyone know what is happening? All my USB ports are 3.0 and I also have a USB 3.0 Hub connected to my laptop using a USB-C port (the microphone is connected to this hub). I'm also using a gaming mouse connected directly to my laptop. Everything is connected directly to my laptop except the microphone which is connected to the USB Hub using the USB-C port.
Any help would be appreciated!
Thank you
Thank you
