philtrick123
Hi,
I'm using OBS with the Replay Source plugin to record a golf swing.
When I got into the camera setup (it's a standard plug and play uvc webcam)the offered resolution and frame rates do not match the camera. I tried amcap and Kinovea and the both offer the correct resolution and frame rate. Should OBS correctly 'pull' the res and fps capabilities from the camera?
Thanks.
Thanks.
