Question / Help Using OBS Studio PC going to SlowMotion HElP
DerVikingz
Hy at all ( My English is not very good)
So my problem is, when i Streaming with Obs Studio the Game was i Playing is in Slow Motion but the Frames on 60 Fps.
I played Resident Evil 4 Cpu Usage by 40 Procent. I Tested an Snes Emulator and here is the same.
Every Game i Stream is in 2- 5 min in Slow Motion.
Pc Specs:
Amd FX 6100
Gtx 650 1 Gb
Obs Studio 1280x720
Cpu VeryFast
Maybe the Cpu is Crap ?
Thanks for your Answers
DerVikingz
09:50:40.124: CPU Name: AMD FX(tm)-6100 Six-Core Processor
09:50:40.124: CPU Speed: 3315MHz
09:50:40.124: Physical Cores: 3, Logical Cores: 6
09:50:40.124: Physical Memory: 12270MB Total, 10997MB Free
09:50:40.124: Windows Version: 6.3 Build 9600 (revision: 17056)
09:50:40.125: Aero is Enabled (Aero is always on for windows 8 and above)
09:50:40.143: OBS 0.14.1 (64bit, windows)
09:50:40.143: ---------------------------------
09:50:40.144: audio settings reset:
09:50:40.144: samples per sec: 44100
09:50:40.144: speakers: 2
09:50:40.145: ---------------------------------
09:50:40.145: Initializing D3D11..
09:50:40.145: Available Video Adapters:
09:50:40.145: Adapter 1: NVIDIA GeForce GTX 650
09:50:40.145: Dedicated VRAM: 2082140160
09:50:40.145: Shared VRAM: 2147807232
09:50:40.145: output 1: pos={0, 0}, size={1920, 1080}, attached=true
09:50:40.148: Loading up D3D11 on adapter NVIDIA GeForce GTX 650 (0)
09:50:40.167: D3D11 loaded sucessfully, feature level used: 45056
09:50:40.925: ---------------------------------
09:50:40.925: video settings reset:
09:50:40.925: base resolution: 1920x1080
09:50:40.925: output resolution: 1280x720
09:50:40.925: fps: 48/1
09:50:40.925: format: NV12
09:50:40.927: ---------------------------------
09:50:40.928: Loading module: coreaudio-encoder.dll
09:50:40.929: [CoreAudio encoder]: Failed loading library 'CoreAudioToolbox.dll'
09:50:40.929: [CoreAudio encoder]: Couldn't load CoreAudio AAC encoder
09:50:40.929: ---------------------------------
09:50:40.929: Loading module: image-source.dll
09:50:40.930: Loading module: obs-ffmpeg.dll
09:50:40.931: NVENC supported
09:50:40.931: ---------------------------------
09:50:40.931: Loading module: obs-filters.dll
09:50:40.932: ---------------------------------
09:50:40.933: Loading module: obs-outputs.dll
09:50:40.933: ---------------------------------
09:50:40.933: Loading module: obs-qsv11.dll
09:50:40.967: ---------------------------------
09:50:40.968: Loading module: obs-transitions.dll
09:50:40.968: ---------------------------------
09:50:40.968: Loading module: obs-x264.dll
09:50:40.969: ---------------------------------
09:50:40.969: Loading module: rtmp-services.dll
09:50:40.970: ---------------------------------
09:50:40.970: Loading module: text-freetype2.dll
09:50:40.973: ---------------------------------
09:50:40.973: Loading module: win-capture.dll
09:50:41.153: ---------------------------------
09:50:41.153: Loading module: win-decklink.dll
09:50:41.157: No blackmagic support
09:50:41.157: Failed to start search for DeckLink devices
09:50:41.157: ---------------------------------
09:50:41.158: Loading module: win-dshow.dll
09:50:41.161: ---------------------------------
09:50:41.162: Loading module: win-mf.dll
09:50:41.163: [Media Foundation encoder]: Adding Media Foundation AAC Encoder
09:50:41.164: ---------------------------------
09:50:41.164: Loading module: win-wasapi.dll
09:50:41.165: =====================================================================
09:50:41.165: output 'simple_stream' (rtmp_output) created
09:50:41.165: encoder 'simple_h264_stream' (obs_x264) created
09:50:41.165: AAC encoder bitrate mapping:
09:50:41.165: 32 kbit/s: 'FFmpeg Standard AAC Encoder' (ffmpeg_aac)
09:50:41.165: 64 kbit/s: 'FFmpeg Standard AAC Encoder' (ffmpeg_aac)
09:50:41.165: 96 kbit/s: 'Media Foundation AAC Encoder' (mf_aac)
09:50:41.165: 128 kbit/s: 'Media Foundation AAC Encoder' (mf_aac)
09:50:41.165: 160 kbit/s: 'Media Foundation AAC Encoder' (mf_aac)
09:50:41.165: 192 kbit/s: 'Media Foundation AAC Encoder' (mf_aac)
09:50:41.165: 224 kbit/s: 'FFmpeg Standard AAC Encoder' (ffmpeg_aac)
09:50:41.165: 256 kbit/s: 'FFmpeg Standard AAC Encoder' (ffmpeg_aac)
09:50:41.165: 288 kbit/s: 'FFmpeg Standard AAC Encoder' (ffmpeg_aac)
09:50:41.165: 320 kbit/s: 'FFmpeg Standard AAC Encoder' (ffmpeg_aac)
09:50:41.165: encoder 'simple_aac' (mf_aac) created
09:50:41.166: output 'simple_file_output' (ffmpeg_muxer) created
09:50:41.166: service 'default_service' (rtmp_common) created
09:50:41.167: All scene data cleared
09:50:41.167: ------------------------------------------------
09:50:41.191: WASAPI: Device 'Digitalaudio (S/PDIF) (High Definition Audio-Gerät)' initialized
09:50:41.191: source 'Desktop Audio' (wasapi_output_capture) created
09:50:41.191: source 'Fensteraufnahme' (window_capture) created
09:50:41.192: source 'Spielaufnahme 1' (game_capture) create
  • 2016-05-04 09-50-40.txt
