Using Behringer UCA202 Not seeing audio meter move in OBS
DJThunderLove
Hi there. I have a macbook Pro 2023, running Sequoia 15.6.1 MacOS, have Behringer UCA202 connected to laptop and output of my Pioneer DDJ1000. The mac only has usb-c ports, but I have an approved port converter to plug usba cables into the laptop. I don't know if that is the issue, but the laptop recognizes the U-control interface. I am not seeing any meters moving in OBS. I have mic-auxillary audio set to "USB Audio Codec", which is how the laptop recognizes the uca202. RCA cables running from my DDJ1000 into the input RCA of the UCA202.
I've done all the settings as per the instruction videos. Any thoughts on how to resolve this? Pretty please?
Hi, I hope I can help you if you haven't already solved it: the sound card connection must be done directly, not through a hub, so you will need a USBC cable to the computer and a female USBA to connect your UCA202, this is probably just the problem.
