Using ATEM Mini Iso Pro with OBS - Fixing Issues
ProducerSean
Hey Everyone, i just found an interesting fix for a problem we were having when bringing in our Atem feed via the USB-C port. Our video was jittery almost as if it was dropping frames. The solution was to right click on the program window in OBS and select "linear" from the "deinterlacing" menu. So if you're connecting your Atem Mini to OBS via the USB-C connection and cannot figure out why the signal is jittery or not smooth, try selecting a different Deinterlacing option in OBS and you should see it improve!
