FUMC Osage
I am thinking of pulling my old analog audio mixer out of my setup. I am considering 3 separate USB audio capture devices or a 3-4 channel USB mixer.
The setup is for a church. I have 3 audio sources, microphone on piano, stereo audio output from an organ and the audio output from a 12 channel Peavey analog mixer for multiple microphone inputs. Because I don't need the organ or the piano going through the main mixer, I am using the separate analog mixer (Realistic 5 channel mixer) for my stream setup. The problem I am having is getting the right level set. I barely have to move the sliders (just touch them) up on the piano or the organ, and they are overpowering the input levels of my current capture device, yet vocal audio from the Peavey Mixer are normal.
Because OBS can have multiple audio inputs I am thinking separate devices. I would be able to control each individual input at the computer. But also a USB mixer would simplify my hookups but would I have the same issue as now with the analog mixer?
Any help with this would be appreciated.
TSJ
TSJ
