Trouble Sending Audio From Reaper Using ReaRoute
MissJoanna2U
Hi There,
I want to use OBS in conjunction with Reaper to record myself playing various instruments and my external microphone via my Focusrite 2i2.
The sound is really distorted and the signal very weak.
The method I am using was taken from https://www.youtube.com/watch?v=Pth45XWGaFk&t=239s
Reaper is using a sample rate of 48kHz in 24bit, windows is using 48kHz via the Focusrite and I have set OBS to use that sample rate as well.
None of the meters in OBS are in the red, though I'm unsure if I need all that are visible.
I've tried only using the Reaper input and all variations of them and nothing works.
This is the log file https://obsproject.com/logs/6QixuZq78K7jFBXV
I'd be grateful for any input.
