streamingguy
Currently, whenever you add a new source, the option for "Audio Monitoring" in Advanced Audio Properties is set to "Monitor Off." However, I use a program called voicemeeter, which gives me greater control of my sound, but the drawback to that is whenever I add a new source that is a local file (video, mp3, etc.) it outputs just fine, but I am unable to hear it. Setting the source's Audio Monitoring to "Monitor Only (mute output)" fixes this, but the problem is that sources play automatically when added, so each time I do this, there will always be a split second of the source playing without me being able to hear. Adding an option to choose which Audio Monitoring option is selected by default for new sources would be a tremendous help.
