7sDream
Log
Screenshot:
When I click [start record] or [start stream] button, the application disappear, So I run it in teriminal, I got the last error report:
'obs' terminated by signal SIGSEGV (Address boundary error)
my system is Deepin Linux, based on Debian.
Is it a bug? Or some setting/system env error?
00时22分24秒.927: Processor: 4 logical cores
00时22分24秒.927: Processor: Intel(R) Core(TM) i7-4500U CPU @ 1.80GHz
00时22分24秒.928: Physical Memory: 7710MB Total
00时22分24秒.928: Kernel Version: Linux 4.2.0-1-amd64
00时22分24秒.928: Distribution: "Deepin" "15.1.1"
00时22分24秒.946: OBS 0.13.1 (linux)
00时22分24秒.946: ---------------------------------
00时22分24秒.948: ---------------------------------
00时22分24秒.948: audio settings reset:
00时22分24秒.948: samples per sec: 44100
00时22分24秒.948: speakers: 2
00时22分24秒.987: OpenGL version: 3.3 (Core Profile) Mesa 11.1.2
00时22分24秒.987:
00时22分25秒.058: ---------------------------------
00时22分25秒.058: video settings reset:
00时22分25秒.058: base resolution: 1366x768
00时22分25秒.058: output resolution: 1364x768
00时22分25秒.058: fps: 30/1
00时22分25秒.058: format: NV12
00时22分25秒.059: ---------------------------------
00时22分25秒.060: Loading module: image-source.so
00时22分25秒.060: ---------------------------------
00时22分25秒.061: Loading module: linux-capture.so
00时22分25秒.062: ---------------------------------
00时22分25秒.063: Loading module: linux-decklink.so
00时22分25秒.063: No blackmagic support
00时22分25秒.063: Failed to start search for DeckLink devices
00时22分25秒.063: ---------------------------------
00时22分25秒.065: Loading module: linux-jack.so
00时22分25秒.065: ---------------------------------
00时22分25秒.075: Loading module: linux-pulseaudio.so
00时22分25秒.075: ---------------------------------
00时22分25秒.077: Loading module: linux-v4l2.so
00时22分25秒.077: ---------------------------------
00时22分25秒.080: Loading module: obs-ffmpeg.so
00时22分25秒.080: ---------------------------------
00时22分25秒.084: Loading module: obs-filters.so
00时22分25秒.084: ---------------------------------
00时22分25秒.085: Loading module: obs-libfdk.so
00时22分25秒.086: ---------------------------------
00时22分25秒.087: Loading module: obs-outputs.so
00时22分25秒.087: ---------------------------------
00时22分25秒.088: Loading module: obs-transitions.so
00时22分25秒.088: ---------------------------------
00时22分25秒.089: Loading module: obs-x264.so
00时22分25秒.089: ---------------------------------
00时22分25秒.090: Loading module: rtmp-services.so
00时22分25秒.091: ---------------------------------
00时22分25秒.091: Loading module: text-freetype2.so
00时22分25秒.092: =====================================================================
00时22分25秒.092: output 'adv_stream' (rtmp_output) created
00时22分25秒.092: output 'adv_file_output' (ffmpeg_muxer) created
00时22分25秒.092: encoder 'streaming_h264' (obs_x264) created
00时22分25秒.093: AAC encoder bitrate mapping:
00时22分25秒.093: 32 kbit/s: 'libfdk AAC 编码器' (libfdk_aac)
00时22分25秒.093: 64 kbit/s: 'libfdk AAC 编码器' (libfdk_aac)
00时22分25秒.093: 96 kbit/s: 'libfdk AAC 编码器' (libfdk_aac)
00时22分25秒.093: 128 kbit/s: 'libfdk AAC 编码器' (libfdk_aac)
00时22分25秒.093: 160 kbit/s: 'libfdk AAC 编码器' (libfdk_aac)
00时22分25秒.093: 192 kbit/s: 'libfdk AAC 编码器' (libfdk_aac)
00时22分25秒.093: 224 kbit/s: 'libfdk AAC 编码器' (libfdk_aac)
00时22分25秒.093: 256 kbit/s: 'libfdk AAC 编码器' (libfdk_aac)
00时22分25秒.093: 288 kbit/s: 'FFmpeg 默认 AAC 编码器' (ffmpeg_aac)
00时22分25秒.093: 320 kbit/s: 'FFmpeg 默认 AAC 编码器' (ffmpeg_aac)
00时22分25秒.093: encoder 'adv_aac0' (libfdk_aac) created
00时22分25秒.093: encoder 'adv_aac1' (libfdk_aac) created
00时22分25秒.093: encoder 'adv_aac2' (libfdk_aac) created
00时22分25秒.093: encoder 'adv_aac3' (libfdk_aac) created
00时22分25秒.093: service 'default_service' (rtmp_common) created
00时22分25秒.103: All scene data cleared
00时22分25秒.103: ------------------------------------------------
00时22分25秒.117: pulse-input: Server name: 'pulseaudio 8.0'
00时22分25秒.118: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
00时22分25秒.118: pulse-input: Started recording from 'alsa_output.pci-0000_00_1b.0.analog-stereo.monitor'
00时22分25秒.119: source '台式音响' (pulse_output_capture) created
00时22分25秒.121: pulse-input: Server name: 'pulseaudio 8.0'
00时22分25秒.122: pulse-input: Audio format: s16le, 48000 Hz, 2 channels
00时22分25秒.123: pulse-input: Started recording from 'alsa_input.pci-0000_00_1b.0.analog-stereo'
00时22分25秒.123: source '麦克风/Aux' (pulse_input_capture) created
00时22分25秒.123: source '噪音阈值' (noise_gate_filter) created
00时22分25秒.146: source 'Chrome' (xcomposite_input) created
00时22分25秒.187: source '背景' (image_source) created
00时22分25秒.187: source '桌面' (scene) created
00时22分25秒.264: == Profiler Results =============================
00时22分25秒.264: run_program_init: 389.72 ms
00时22分25秒.264: ┣OBSApp::AppInit: 1.349 ms
00时22分25秒.264: ┃ ┗OBSApp::InitLocale: 1.13 ms
00时22分25秒.264: ┗OBSApp::OBSInit: 357.515 ms
00时22分25秒.264: ┣obs_startup: 1.433 ms
00时22分25秒.264: ┗OBSBasic::OBSInit: 317.386 ms
00时22分25秒.264: ┣OBSBasic::InitBasicConfig: 1.694 ms
00时22分25秒.264: ┣OBSBasic::ResetAudio: 0.273 ms
00时22分25秒.264: ┣OBSBasic::ResetVideo: 110.813 ms
00时22分25秒.264: ┣OBSBasic::InitOBSCallbacks: 0.025 ms
00时22分25秒.264: ┣OBSBasic::InitHotkeys: 0.131 ms
00时22分25秒.264: ┣obs_load_all_modules: 32.982 ms
00时22分25秒.264: ┃ ┣obs_init_module(image-source.so): 0.002 ms
00时22分25秒.264: ┃ ┣obs_init_module(linux-capture.so): 0.639 ms
00时22分25秒.264: ┃ ┣obs_init_module(linux-decklink.so): 0.22 ms
00时22分25秒.264: ┃ ┣obs_init_module(linux-jack.so): 0.004 ms
00时22分25秒.264: ┃ ┣obs_init_module(linux-pulseaudio.so): 0.006 ms
00时22分25秒.264: ┃ ┣obs_init_module(linux-v4l2.so): 0.003 ms
00时22分25秒.264: ┃ ┣obs_init_module(obs-ffmpeg.so): 0.009 ms
00时22分25秒.264: ┃ ┣obs_init_module(obs-filters.so): 0.014 ms
00时22分25秒.264: ┃ ┣obs_init_module(obs-libfdk.so): 0.003 ms
00时22分25秒.264: ┃ ┣obs_init_module(obs-outputs.so): 0.004 ms
00时22分25秒.264: ┃ ┣obs_init_module(obs-transitions.so): 0.004 ms
00时22分25秒.264: ┃ ┣obs_init_module(obs-x264.so): 0.003 ms
00时22分25秒.264: ┃ ┣obs_init_module(rtmp-services.so): 0.107 ms
00时22分25秒.264: ┃ ┗obs_init_module(text-freetype2.so): 0.129 ms
00时22分25秒.264: ┣OBSBasic::ResetOutputs: 1.112 ms
00时22分25秒.264: ┣OBSBasic::CreateHotkeys: 0.089 ms
00时22分25秒.264: ┣OBSBasic::InitService: 0.259 ms
00时22分25秒.264: ┣OBSBasic::InitPrimitives: 8.872 ms
00时22分25秒.264: ┗OBSBasic::Load: 87.781 ms
00时22分25秒.264: =================================================
00时22分25秒.680: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
00时22分26秒.666: Update check: last known remote version is 0.4.0
00时22分28秒.721: ---------------------------------
00时22分28秒.721: [x264 encoder: 'streaming_h264'] preset: veryfast
00时22分28秒.721: [x264 encoder: 'streaming_h264'] settings:
00时22分28秒.721: bitrate: 2500
00时22分28秒.721: buffer size: 2500
00时22分28秒.721: crf: 0 (0 when CBR is enabled)
00时22分28秒.721: fps_num: 30
00时22分28秒.721: fps_den: 1
00时22分28秒.721: width: 1364
00时22分28秒.721: height: 768
00时22分28秒.721: keyint: 250
00时22分28秒.721: vfr: off
00时22分28秒.721: cbr: on
Screenshot:
