Question / Help System Audio sliders not affecting OBS?
Insomniac
Hello,
Looking for some help trying to control desktop audio. For some reason, OBS will record desktop audio at 100% regardless of what the system volume is set to and only accept changes made via the OBS slider. While this still works, it prevents me from being able to hear exactly what is being recorded/sent out.
Is there a setting/issue I am skipping that would allow changes made to the default device volume to affect OBS? Attached a snip of the settings. Volume Control for the computer is at 0 and can even by muted, but OBS will still record Desktop Audio.
Any help would be appreciated.
06:31:30.244: CPU Name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
06:31:30.244: CPU Speed: 4008MHz
06:31:30.244: Physical Cores: 4, Logical Cores: 8
06:31:30.244: Physical Memory: 16301MB Total, 8194MB Free
06:31:30.244: Windows Version: 6.1 Build 7601 (revision: 23572; 64-bit)
06:31:30.244: Running as administrator: false
06:31:30.244: Aero is Enabled
06:31:30.246: Portable mode: false
06:31:30.262: OBS 17.0.0 (64bit, windows)
06:31:30.262: ---------------------------------
06:31:30.263: ---------------------------------
06:31:30.263: audio settings reset:
06:31:30.263:     samples per sec: 44100
06:31:30.263:     speakers:        2
06:31:30.265: ---------------------------------
06:31:30.265: Initializing D3D11..
06:31:30.265: Available Video Adapters:
06:31:30.267:     Adapter 1: NVIDIA GeForce GTX 1080
06:31:30.267:       Dedicated VRAM: 4182441984
06:31:30.267:       Shared VRAM:    3983513600
06:31:30.267:       output 1: pos={0, 0}, size={1920, 1080}, attached=true
06:31:30.267:       output 2: pos={-1920, 547}, size={1920, 1080}, attached=true
06:31:30.267:       output 3: pos={1920, 700}, size={1920, 1080}, attached=true
06:31:30.270: Loading up D3D11 on adapter NVIDIA GeForce GTX 1080 (0)
06:31:30.276: D3D11 loaded sucessfully, feature level used: 45056
06:31:30.916: ---------------------------------
06:31:30.916: video settings reset:
06:31:30.916:     base resolution:   1920x1080
06:31:30.916:     output resolution: 1280x720
06:31:30.916:     downscale filter:  Lanczos
06:31:30.916:     fps:               30/1
06:31:30.916:     format:            NV12
06:31:30.917: ---------------------------------
06:31:30.929: [CoreAudio encoder]: Adding CoreAudio AAC encoder
06:31:30.932: [AMF Encoder] Unable to load 'amfrt64.dll', error code 126.
06:31:30.933: [AMF Encoder] able to load 'amfrt64.dll', error code 126.
06:31:30.964: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
06:31:30.965: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
06:31:30.967: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
06:31:30.968: Failed to load 'en-US' text for module: 'obs-browser.dll'
06:31:30.968: [browser_source: 'Version: 1.27.0']
06:31:30.981: NVENC supported
06:31:31.063: VLC found, VLC video source enabled
06:31:31.073: No blackmagic support
06:31:31.081: [Media Foundation encoder]: plugin is disabled for performance reasons on Windows versions prior to 8
06:31:31.085: ---------------------------------
06:31:31.085:   Loaded Modules:
06:31:31.085:     win-wasapi.dll
06:31:31.085:     win-mf.dll
06:31:31.085:     win-dshow.dll
06:31:31.085:     win-decklink.dll
06:31:31.085:     win-capture.dll
06:31:31.085:     vlc-video.dll
06:31:31.085:     text-freetype2.dll
06:31:31.085:     rtmp-services.dll
06:31:31.085:     obs-x264.dll
06:31:31.085:     obs-transitions.dll
06:31:31.085:     obs-text.dll
06:31:31.085:     obs-qsv11.dll
06:31:31.085:     obs-outputs.dll
06:31:31.085:     obs-filters.dll
06:31:31.085:     obs-ffmpeg.dll
06:31:31.085:     obs-browser.dll
06:31:31.085:     image-source.dll
06:31:31.085:     frontend-tools.dll
06:31:31.085:     enc-amf.dll
06:31:31.085:     coreaudio-encoder.dll
06:31:31.085: ==== Startup complete ===============================================
06:31:31.109: All scene data cleared
06:31:31.109: ------------------------------------------------
06:31:31.122: WASAPI: Device 'Speakers (2- Line 6 UX2)' initialized
06:31:31.130: WASAPI: Device 'Digital Audio Interface (2- Line 6 UX2)' initialized
06:31:31.209: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
06:31:33.117: Switched to scene 'Desktop'
06:31:33.150: ------------------------------------------------
06:31:33.150: Loaded scenes:
06:31:33.150: - scene 'Scene':
06:31:33.150:     - source: 'Image Slide Show' (slideshow)
06:31:33.150:     - source: 'Image' (image_source)
06:31:33.150: - scene 'Desktop':
06:31:33.150:     - source: 'Display Capture' (monitor_capture)
06:31:33.150: - scene 'PC Game':
06:31:33.150:     - source: 'Game Capture' (game_capture)
06:31:33.395: Update check: last known remote version is 17.0.0
06:31:45.223: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
06:34:13.086: adding 23 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
06:39:03.722: adding 23 milliseconds of audio buffering, total audio buffering is now 92 milliseconds
06:41:21.050: adding 23 milliseconds of audio buffering, total audio buffering is now 116 milliseconds
07:11:42.117: Update check: last known remote version is 17.0.0
Insomniac
Also tried utilizing Voicemeeter to try and circumvent this, but the effect remains the same. Even with Voicemeeter set as the default and faders set to as low as possible, the sound being recorded by OBS is 100%.
Insomniac
Seems even OBS classic behaves the same. Is it just set up to capture the sound before it hits the system slider or just bypass it?
Gol D. Ace
This is AFAIK just the way WASAPI (Windows Audio Session API) works.
This slider only affects the output volume for the device not the actual volume.
What you can do is turning down the volume for every application separately. That will work.
Insomniac
Ah, I see. Least that ends me freaking out about something being wrong. I appreciate the input, least now I can plan around that.
