04:45:42.044: CPU Name: AMD FX(tm)-8350 Eight-Core Processor
04:45:42.045: CPU Speed: 4018MHz
04:45:42.045: Physical Cores: 4, Logical Cores: 8
04:45:42.045: Physical Memory: 16366MB Total, 12920MB Free
04:45:42.045: Windows Version: 10.0 Build 14393 (revision: 953; 64-bit)
04:45:42.045: Running as administrator: false
04:45:42.045: Aero is Enabled (Aero is always on for windows 8 and above)
04:45:42.045: Portable mode: false
04:45:42.055: OBS 18.0.1 (64bit, windows)
04:45:42.056: ---------------------------------
04:45:42.056: audio settings reset:
04:45:42.056: samples per sec: 44100
04:45:42.056: speakers: 2
04:45:42.058: ---------------------------------
04:45:42.058: Initializing D3D11..
04:45:42.058: Available Video Adapters:
04:45:42.060: Adapter 1: Radeon(TM) RX 460 Graphics
04:45:42.060: Dedicated VRAM: 4240543744
04:45:42.060: Shared VRAM: 4285575168
04:45:42.060: output 1: pos={0, 0}, size={1920, 1080}, attached=true
04:45:42.062: Loading up D3D11 on adapter Radeon(TM) RX 460 Graphics (0)
04:45:42.117: D3D11 loaded sucessfully, feature level used: 45056
04:45:43.005: ---------------------------------
04:45:43.005: video settings reset:
04:45:43.005: base resolution: 1920x1080
04:45:43.005: output resolution: 1280x720
04:45:43.005: downscale filter: Lanczos
04:45:43.005: fps: 30/1
04:45:43.005: format: NV12
04:45:43.006: Audio monitoring device:
04:45:43.006: name: Default
04:45:43.006: id: default
04:45:43.006: ---------------------------------
04:45:43.007: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
04:45:43.008: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
04:45:43.041: [AMF Encoder] Version 1.4.3.11 loaded (Compiled: 1.3.0.5, Runtime: 1.4.2.0, Library: 1;4;2;0;17.10.1711;201704101313;CL#1396327).
04:45:43.824: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
04:45:43.825: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
04:45:43.825: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
04:45:43.826: Failed to load 'en-US' text for module: 'obs-browser.dll'
04:45:43.826: [browser_source: 'Version: 1.29.0']
04:45:43.828: NVENC supported
04:45:43.947: Couldn't find VLC installation, VLC video source disabled
04:45:43.952: No blackmagic support
04:45:44.056: ---------------------------------
04:45:44.056: Loaded Modules:
04:45:44.056: win-wasapi.dll
04:45:44.056: win-mf.dll
04:45:44.056: win-dshow.dll
04:45:44.056: win-decklink.dll
04:45:44.056: win-capture.dll
04:45:44.056: vlc-video.dll
04:45:44.056: text-freetype2.dll
04:45:44.056: rtmp-services.dll
04:45:44.056: obs-x264.dll
04:45:44.056: obs-vst.dll
04:45:44.056: obs-transitions.dll
04:45:44.056: obs-text.dll
04:45:44.056: obs-qsv11.dll
04:45:44.056: obs-outputs.dll
04:45:44.056: obs-filters.dll
04:45:44.056: obs-ffmpeg.dll
04:45:44.056: obs-browser.dll
04:45:44.056: image-source.dll
04:45:44.056: frontend-tools.dll
04:45:44.056: enc-amf.dll
04:45:44.056: coreaudio-encoder.dll
04:45:44.056: ==== Startup complete ===============================================
04:45:44.058: All scene data cleared
04:45:44.058: ------------------------------------------------
04:45:44.134: WASAPI: Device 'Speakers (VIA HD Audio)' initialized
04:45:44.135: [WASAPISource::TryInitialize]:[Microphone (3- USB PnP Sound Device)] Failed to activate client context: 88890004
04:45:44.135: [WASAPISource::WASAPISource] Device '{0.0.1.00000000}.{33ebbd48-7aeb-4f15-953e-fa9d53789f0f}' not found. Waiting for device
04:45:44.282: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
04:45:44.338: WASAPI: Device 'Microphone (HD Webcam C270)' initialized
04:45:44.343: Switched to scene 'Scene'
04:45:44.343: ------------------------------------------------
04:45:44.343: Loaded scenes:
04:45:44.343: - scene 'Scene':
04:45:44.343: - source: 'Image' (image_source)
04:45:44.343: - source: 'Audio Input Capture' (wasapi_input_capture)
04:45:44.343: - source: 'Video Capture Device' (dshow_input)
04:45:44.343: - source: 'Video Capture Device 2' (dshow_input)
04:45:44.438: ---------------------------------
04:45:44.438: [DShow Device: 'Video Capture Device'] settings updated:
04:45:44.438: video device: AVerMedia HD Capture C985 Bus 2
04:45:44.438: video path: \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&9d12143&0&0020#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a}
04:45:44.438: resolution: 1280x720
04:45:44.438: fps: 30.00 (interval: 333333)
04:45:44.438: format: YV12
04:45:44.440: using video device audio: yes
04:45:44.440: sample rate: 48000
04:45:44.440: channels: 2
04:45:44.440: audio type: Capture
04:45:44.443: ---------------------------------
04:45:44.443: [DShow Device: 'Video Capture Device 2'] settings updated:
04:45:44.443: video device: Logitech HD Webcam C270
04:45:44.443: video path: \\?\usb#vid_046d&pid_0825&mi_00#6&302aa1b5&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
04:45:44.443: resolution: 640x480
04:45:44.443: fps: 30.00 (interval: 333333)
04:45:44.443: format: I420
04:45:45.411: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
04:46:18.312: Settings changed (outputs)
04:46:18.312: ------------------------------------------------
04:46:20.026: DShow: Failed to connect output to device (0x80004005): Unspecified error
04:46:20.026:
04:46:20.026: DShow: Failed to connect encoder filters
04:46:20.027: [Media Foundation AAC: 'Track1']: encoder created
04:46:20.027: bitrate: 160
04:46:20.027: channels: 2
04:46:20.027: sample rate: 44100
04:46:20.027: bits-per-sample: 16
04:46:20.027:
04:46:20.032: ==== Recording Start ===============================================
04:46:20.032: [ffmpeg muxer: 'adv_file_output'] Writing file 'B:/Video/2017-04-14 04-46-20.flv'...
04:46:20.145: Error encoding with encoder 'recording_h264'
04:55:53.364: ==== Shutting down ==================================================
04:55:53.372: Switched to scene '(null)'
04:55:53.375: WASAPI: Device 'Microphone (HD Webcam C270)' Terminated
04:55:54.277: WASAPI: Device 'Speakers (VIA HD Audio)' Terminated
04:55:54.293: All scene data cleared
04:55:54.293: ------------------------------------------------
