Question / Help StreamLabs Alert Double sound fix
TastyHam
Hey guys
I had a little problem recently and i saw how to fix it very easily.
So if you guy have double streamlabs alert sounds just remove your scene and make another one, as simple as that.
This worked for me, if this works well hit me up :)
If this don't works i recommend you to delete everything (all scenes and sources) then re create new ones.
Bye!
Harold
Use add existing source to add your alerts to multiple scenes rather than add new source.
