Nicholas Bocchi
TL;DR I stream and record on obs with multitrack audio. In order to listen to everything i am using a Virtual Mixer, but it is causing CPU issues. I think I need to buy a Mixer, but don`t know how they work. What should I buy?
I will say what I need and the setups I THINK will resolve my problem, but I don't know what equips I need or if it is even possible. In the end the questions that remain.
Keep in mind I know almost nothing about audio gear, everything I gathered was from google, but I didn't find anything that answers my questions. So I am here seeking help from you guys.
CURRENTLY:
I stream and record with obs 3/4 different audio sources by directing the audio for 3/4 different output devices:
- Game/Desktop (sometimes the game doesn't allow to set a output device)
- Desktop
- Comms (Discord/Skype/TS)
- Music (Spotify with Equalify Plugin, allowing me to set a output device)
In adition I have the mic:
- Mic Razer Seiren Pro (Currently USB, but it has XLR option)
In order to listen everything, I run a virtual mixer (VoiceMeeter Banana), but it is too much for my CPU.
If I want to put everything into the mixer, I need at least 10 channels (4 stereo "devices" + Razer Seiren Pro 2x 3-pin XLR Cable)
Razer Seiren Pro Cable: http://prntscr.com/dr5fx5
Razer Seiren Pro Back: http://prntscr.com/dr5esd
SETUP 1 (probably cheaper):
Mixer with 10 Channels in and at least 2 out.
What goes in the mixer:
- Game (out of PC)
- Comms (out of PC)
- Music (out of PC)
- Desktop (out of PC)
- MIC (2x 3-pin XLR cable)
What goes out the mixer into my PC:
- MIC
Phones into the mixer listening to:
- Game
- Comms
- Music
- Desktop
OBS capturing:
- Game (as PC device)
- Comms (as PC device)
- Music (as PC device)
- Desktop (as PC device)
- MIC (from Mixer)
SETUP 2 (probably more expensive):
Mixer with 10 Channels in and 10 out.
Probably I will need an audio Interface with 10 in for PC.
- Game (out of PC)
- Comms (out of PC)
- Music (out of PC)
What goes out the mixer and into my PC:
- Game
- Comms
- Music
- Desktop
- MIC
- Game
- Comms
- Music
- Desktop
OBS capturing:
- Game (from Mixer)
- Comms (from Mixer)
- Music (from Mixer)
- Desktop (from Mixer)
- MIC (from Mixer)
QUESTIONS:
1 - Is it possible to set what the phones connected to the mixer will listen? (remove only the mic)
2 - If 1 is possible; what Mixer for Setup 1 do you recommend?
3 - If 1 is possible; what Mixer and Audio Interface for Setup 2 do you recommend?
4 - If 1 is not possible; what do you recommend?
CURRENTLY:
- Desktop
- Game (out of PC)
- Comms (out of PC)
- Music (out of PC)
- MIC
- Game
- Comms
- Music
- Desktop
OBS capturing:
- MIC (from Mixer)
- Game (out of PC)
- Comms (out of PC)
- Music (out of PC)
- Game
- Comms
- Music
- Desktop
- MIC
- Game
- Comms
- Music
- Desktop
OBS capturing:
- Game (from Mixer)
- MIC (from Mixer)
QUESTIONS:
