Stream drops frames after zero dropped for 50 minutes. Logs in description HELP
KLOUDTV
18:23:33.034: CPU Name: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
18:23:33.034: CPU Speed: 2592MHz
18:23:33.034: Physical Cores: 6, Logical Cores: 12
18:23:33.034: Physical Memory: 24418MB Total, 18391MB Free
18:23:33.034: Windows Version: 10.0 Build 19042 (release: 2009; revision: 1110; 64-bit)
18:23:33.034: Running as administrator: false
18:23:33.034: Aero is Enabled (Aero is always on for windows 8 and above)
18:23:33.034: Windows 10 Gaming Features:
18:23:33.034: Game Bar: Off
18:23:33.034: Game DVR: Off
18:23:33.034: Game DVR Background Recording: Off
18:23:33.034: Game Mode: Off
18:23:33.035: Hardware GPU Scheduler: On
18:23:33.037: Sec. Software Status:
18:23:33.038: Norton Security Ultra: disabled (AV)
18:23:33.039: Microsoft Defender Antivirus: enabled (AV)
18:23:33.039: Norton Security Ultra: disabled (FW)
18:23:33.039: Windows Firewall: enabled (FW)
18:23:33.040: Current Date/Time: 2021-07-27, 18:23:33
18:23:33.040: Browser Hardware Acceleration: true
18:23:33.040: Portable mode: false
18:23:33.525: OBS 27.0.1 (64-bit, windows)
18:23:33.525: ---------------------------------
18:23:33.622: ---------------------------------
18:23:33.622: audio settings reset:
18:23:33.622: samples per sec: 48000
18:23:33.622: speakers: 2
18:23:33.623: ---------------------------------
18:23:33.623: Initializing D3D11...
18:23:33.623: Available Video Adapters:
18:23:33.633: Adapter 0: NVIDIA GeForce GTX 1050
18:23:33.633: Dedicated VRAM: 3141533696
18:23:33.633: Shared VRAM: 4212451328
18:23:33.633: PCI ID: 10de:1c91
18:23:33.633: Driver Version: 30.0.14.7141
18:23:33.633: output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=60, name=
18:23:33.633: output 1: pos={0, -1080}, size={1920, 1080}, attached=true, refresh=30, name=ORION
18:23:33.633: Adapter 1: Intel(R) UHD Graphics 630
18:23:33.633: Dedicated VRAM: 134217728
18:23:33.633: PCI ID: 8086:3e9b
18:23:33.634: Driver Version: 26.20.100.6911
18:23:33.643: Loading up D3D11 on adapter NVIDIA GeForce GTX 1050 (0)
18:23:33.749: D3D11 loaded successfully, feature level used: b000
18:23:33.749: DXGI increase maximum frame latency success
18:23:33.749: D3D11 GPU priority setup failed (not admin?)
18:23:34.306: ---------------------------------
18:23:34.306: video settings reset:
18:23:34.306: base resolution: 1920x1080
18:23:34.306: output resolution: 1920x1080
18:23:34.306: downscale filter: Bilinear
18:23:34.306: fps: 60/1
18:23:34.306: format: NV12
18:23:34.306: YUV mode: 709/Partial
18:23:34.306: NV12 texture support enabled
18:23:34.308: Audio monitoring device:
18:23:34.308: name: Default
18:23:34.308: id: default
18:23:34.310: ---------------------------------
18:23:34.311: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
18:23:34.316: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
18:23:34.317: Failed to load 'en-US' text for module: 'decklink-captions.dll'
18:23:34.319: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
18:23:34.362: [AMF] Unable to load 'amfrt64.dll', error code 126.
18:23:34.364: [AMF] AMF Test failed due to one or more errors.
18:23:34.364: Failed to initialize module 'enc-amf.dll'
18:23:34.464: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
18:23:34.472: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
18:23:34.473: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
18:23:34.479: [obs-browser]: Version 2.14.3
18:23:34.479: [obs-browser]: CEF Version 75.1.16+g16a67c4+chromium-75.0.3770.100
18:23:34.490: NVENC supported
18:23:34.492: [noise suppress: Nvidia RTX denoiser disabled, redistributable not found]
18:23:34.566: VLC found, VLC video source enabled
18:23:34.694: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
18:23:34.695: No blackmagic support
18:23:34.708: ---------------------------------
18:23:34.708: Loaded Modules:
18:23:34.708: win-wasapi.dll
18:23:34.708: win-mf.dll
18:23:34.708: win-dshow.dll
18:23:34.708: win-decklink.dll
18:23:34.708: win-capture.dll
18:23:34.708: vlc-video.dll
18:23:34.708: text-freetype2.dll
18:23:34.708: rtmp-services.dll
18:23:34.708: obs-x264.dll
18:23:34.708: obs-vst.dll
18:23:34.708: obs-transitions.dll
18:23:34.708: obs-text.dll
18:23:34.708: obs-qsv11.dll
18:23:34.708: obs-outputs.dll
18:23:34.708: obs-filters.dll
18:23:34.708: obs-ffmpeg.dll
18:23:34.708: obs-browser.dll
18:23:34.708: image-source.dll
18:23:34.708: frontend-tools.dll
18:23:34.708: enc-amf.dll
18:23:34.708: decklink-ouput-ui.dll
18:23:34.708: decklink-captions.dll
18:23:34.708: coreaudio-encoder.dll
18:23:34.710: ==== Startup complete ===============================================
18:23:34.745: All scene data cleared
18:23:34.745: ------------------------------------------------
18:23:34.881: WASAPI: Device 'VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)' [48000 Hz] initialized
18:23:34.881: [Loaded global audio device]: 'DESKTOP AUDIO'
18:23:34.991: WASAPI: Device 'Microphone Array (Realtek(R) Audio)' [48000 Hz] initialized
18:23:34.991: [noise suppress: 'Noise Suppression'] NVAFX redist is not installed.
18:23:34.992: [Loaded global audio device]: 'MICROPHONE'
18:23:34.992: - filter: 'Noise Suppression' (noise_suppress_filter_v2)
18:23:35.026: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: MICROPHONE)
18:23:35.026:
18:23:35.274: WASAPI: Device 'VoiceMeeter Aux Input (VB-Audio VoiceMeeter AUX VAIO)' [48000 Hz] initialized
18:23:35.555: Switched to scene 'LIVE'
18:23:35.555: ------------------------------------------------
18:23:35.555: Loaded scenes:
18:23:35.555: - scene 'LIVE':
18:23:35.555: - source: 'XBOX VIDEO/AUDIO' (dshow_input)
18:23:35.555: - source: 'Image' (image_source)
18:23:35.556: - source: 'SMOKE EFFECT BEHIND ME' (image_source)
18:23:35.556: - filter: 'Color Correction' (color_filter_v2)
18:23:35.556: - source: 'CAMERA' (dshow_input)
18:23:35.556: - filter: 'Chroma Key' (chroma_key_filter_v2)
18:23:35.556: - filter: 'Crop/Pad' (crop_filter)
18:23:35.556: - source: 'PARTY CHAT' (wasapi_output_capture)
18:23:35.556: - source: 'ALERTS URL ' (browser_source)
18:23:35.556: - source: 'CASH APP' (image_source)
18:23:35.556: - scene 'INTERMISSION':
18:23:35.556: - source: 'SMOKE' (image_source)
18:23:35.556: - source: 'CHAT BLACK BACKGROUND' (image_source)
18:23:35.556: - source: 'CHAT URL' (browser_source)
18:23:35.556: - source: 'BORDER' (image_source)
18:23:35.556: - source: 'XBOX VIDEO/AUDIO' (dshow_input)
18:23:35.556: - source: 'Browser' (browser_source)
18:23:35.556: - scene 'STARTING SOON':
18:23:35.556: - source: 'Image 2' (image_source)
18:23:35.556: - source: 'COUNTDOWN TEXT' (text_gdiplus_v2)
18:23:35.556: - source: 'DESKTOP AUDIO' (wasapi_output_capture)
18:23:35.556: ------------------------------------------------
18:23:36.864: ---------------------------------
18:23:36.864: [DShow Device: 'XBOX VIDEO/AUDIO'] settings updated:
18:23:36.864: video device: Game Capture HD60 S
18:23:36.864: video path: \\?\usb#vid_0fd9&pid_005e#0413929bd0#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{6f814be9-9af6-43cf-9249-c0340100021f}
18:23:36.864: resolution: 1920x1080
18:23:36.864: flip: 0
18:23:36.864: fps: 60.00 (interval: 166666)
18:23:36.864: format: YUY2
18:23:36.898: ---------------------------------
18:23:36.898: [DShow Device: 'CAMERA'] settings updated:
18:23:36.898: video device: HD User Facing
18:23:36.898: video path: \\?\usb#vid_04f2&pid_b64f&mi_00#6&147b4c&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
18:23:36.898: resolution: 1280x720
18:23:36.898: flip: 0
18:23:36.898: fps: 30.00 (interval: 333333)
18:23:36.898: format: MJPEG
18:23:36.947: using video device audio: no
18:23:36.947: separate audio filter
18:23:36.947: sample rate: 44100
18:23:36.947: channels: 2
18:23:36.947: audio type: Capture
18:25:28.783: Settings changed (outputs)
18:25:28.783: ------------------------------------------------
18:40:22.399: User switched to scene 'STARTING SOON'
18:40:22.425: warning: deprecated pixel format used, make sure you did set range correctly
18:40:22.506: adding 64 milliseconds of audio buffering, total audio buffering is now 106 milliseconds (source: XBOX VIDEO/AUDIO)
18:40:22.506:
18:43:05.194: Settings changed (outputs)
18:43:05.194: ------------------------------------------------
18:43:50.027: [jim-nvenc: 'streaming_h264'] settings:
18:43:50.027: rate_control: CBR
18:43:50.027: bitrate: 6000
18:43:50.027: cqp: 20
18:43:50.027: keyint: 120
18:43:50.027: preset: hq
18:43:50.027: profile: high
18:43:50.027: width: 1920
18:43:50.027: height: 1080
18:43:50.027: 2-pass: false
18:43:50.027: b-frames: 2
18:43:50.027: lookahead: false
18:43:50.027: psycho_aq: true
18:43:50.027:
18:43:50.049: ---------------------------------
18:43:50.049: [FFmpeg aac encoder: 'adv_stream_aac'] bitrate: 160, channels: 2, channel_layout: 3
18:43:50.049:
18:43:50.054: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://iad05.contribute.live-video.net/app...
18:43:50.055: [rtmp stream: 'adv_stream'] Binding to IPv4
18:43:50.071: [rtmp stream: 'adv_stream'] Interface: Realtek Gaming GbE Family Controller (ethernet, 1000 mbps)
18:43:51.505: [rtmp stream: 'adv_stream'] Connection to rtmp://iad05.contribute.live-video.net/app successful
18:43:51.513: ==== Streaming Start ===============================================
18:49:30.832: User switched to scene 'INTERMISSION'
18:50:01.137: User switched to scene 'LIVE'
19:36:12.615: [rtmp stream: 'adv_stream'] User stopped the stream
19:36:12.615: Output 'adv_stream': stopping
19:36:12.615: Output 'adv_stream': Total frames output: 179186 (188454 attempted)
19:36:12.615: Output 'adv_stream': Total drawn frames: 188554
19:36:12.615: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 9268 (4.9%)
19:36:12.615: [rtmp stream: 'adv_stream'] Freeing 183 remaining packets
19:36:12.621: ==== Streaming Stop ================================================
19:36:12.664: warning: 2 frames left in the queue on closing
OBS log can't see into what you PC id doing (rare to negatively impact ability to send packets, but possible)
This generally indicates a network issue.. but
- could be something else your PC is doing
- or something else on your LAN competing for upload bandwidth
- your router/WAN link
- with your ISP
