Stream cuts out (OBS turns red) for a second and then reboots stream (happens around every 19-20mins)
reaperfrommars
Exactly every 19-20 minutes my stream turns off and then comes back on a minute later. I have had this problem on my new pc with OBS. It doesn't matter what settings I use. When I opt for performance the same thing happens, when I lower canvases or whatever, when I lower bitrate etc. Nothing seems to fix it, i've tried uninstall and reinstalling, my net is also not the issue. I say this because it never dcs or even causes delay or lag, the stream is smooth and no buffering, it just suddenly turns off. I've done bitrate tests etc, my net can hold up to 9k+. I've also tried the set up wizard, but the same result. Any help would be appreciated.
