Aldebarhan
Hello, good morning, im looking for a solution for this problem for a few days and tested some things i found on the internet "more or less" related about, with no success, im saying that because the problem im having is strange and i found nothing EXACTLY like im having.
The problem is about the capturing of my desktop sound, some kind of "sensitivity" like the one of microphones is working on it, if i have some sound on my desktop with LOW volume the obs is not capturing it, the volume bars doesnt move at all, if the sound turn it up a bit the obs pick it just fine and i can see it perfectly in the bars of volume in obs software. The problem with that is during my gameplay the sounds of the game sometimes are higher, sometimes are lower, background musics happens the same and during the low points of the sound when obs just stop capturing the final result i have on my stream is like im "mute" and "desmute" it all the time during this low sound points, this "cuts" are annoying me.
I tested put my desktop audio in properties with "mono" activated, everything is with 16 bits 48khz (obs and windows mixer)
Tested "untick" the other sound tracks (2,3,4,5,6) in obs audio properties and put "not monitoring" in all sources
None of this worked. Additionally im using voicemeeter banana to separate my discord audio from livestream, but i put everything 16 bits 48khz 2048ms, including voicemeeter painel io, voicemeeter aux painel and voicemeeter banana config.
Maybe im a dumb (started stream 3 weeks ago) but im looking for some kind of "sensitivity" desktop audio adjust on obs and windows and realtek properties and didnt find that. Hopeing that someone here know anything about that and can help me fix. Thank you
