I have a monitor with HDR
I can't set up the color form and space in obs.
If the color space is: sRGB, Rec 709, Rec 601, it doesn't matter what color format I set, the picture will be the same (dark colors, with transparent windows: Screenshot 1). With these settings, you can start broadcasting and video.
If the color space is: Rec.2100(HLG,PQ), color format P010 OR I010, the picture becomes normal (Screenshot 2). But it gives the error Nvenc Error: Failed to perform 10-bit encoding in this encoder when starting the broadcast and recording video. In other color formats, when I use Rec 2100, the error "OBS does not support 8-bit Rec 2100 output"
