Static Noise and No sound via Nvidia DP
Robaz
Hi,
My problem is that i have headphones connected via DP and the sound works just fine but OBS seems to have an issue there.
I have my setup set to get output from the nvidia DP card and the input from the intel card which is the microphone.
Mic works but sound is just static noise no matter what i do, pulseaudio or alsa.
I've tried playing with it a bit and if i set the device to the intel card it works so it's just that Nvidia card :(
Also with noise suppression the static is gone but still no sound.
Any ideas? this sounds like an OBS issue since it works otherwise on everything else.
Robaz
If anyone else finds this.
At the end it was my mistake, i muted the HDMI input in PA since i thought i only needed output and this was causing some other issues.
Check your pactl logs people
