Sound stops when using window capture
efbc sound
New to obs. When using window capture to show power point slides I lose audio part way through live streaming. I have 2 cameras and sound is from mixer through a USB audio interface. Using laptop with Intel i5 processor and 8gig ram.
Do I need to add ram or is there settings that I can change?
Thanks for any help
17:28:43.071: ------------------------------------------------
17:28:43.074: [win-wasapi: 'Desktop Audio'] update settings:
17:28:43.074: device id: {0.0.0.00000000}.{ea5098f9-5cf0-4b43-8d2c-0b6cdcc4586f}
17:28:43.074: use device timing: 1
17:28:43.075: [WASAPISource::TryInitialize]:[Headphones (Realtek(R) Audio)] Failed to activate client context: 88890004
17:28:43.075: WASAPI: Device '{0.0.0.00000000}.{ea5098f9-5cf0-4b43-8d2c-0b6cdcc4586f}' failed to start (source: Desktop Audio)
17:28:43.264: [Loaded global audio device]: 'Desktop Audio'
17:28:43.264: - monitoring: monitor and output
17:28:43.264: [win-wasapi: 'Desktop Audio 2'] update settings:
17:28:43.264: device id: {0.0.0.00000000}.{ea5098f9-5cf0-4b43-8d2c-0b6cdcc4586f}
17:28:43.264: use device timing: 1
17:28:43.264: [Loaded global audio device]: 'Desktop Audio 2'
17:28:43.265: [win-wasapi: 'Mic/Aux'] update settings:
17:28:43.265: device id: default
17:28:43.265: use device timing: 0
17:28:43.265: [WASAPISource::TryInitialize]:[Headphones (Realtek(R) Audio)] Failed to activate client context: 88890004
17:28:43.265: WASAPI: Device '{0.0.0.00000000}.{ea5098f9-5cf0-4b43-8d2c-0b6cdcc4586f}' failed to start (source: Desktop Audio 2)
17:28:43.277: [Loaded global audio device]: 'Mic/Aux'
17:28:43.277: - monitoring: monitor and output
17:28:43.278: [Media Source 'cam']: settings:
17:28:43.278: input: rtsp://192.168.1.16/1
17:28:43.278: input_format:
17:28:43.278: speed: 100
17:28:43.278: is_looping: no
17:28:43.278: is_linear_alpha: no
17:28:43.278: is_hw_decoding: no
17:28:43.278: is_clear_on_media_end: no
17:28:43.278: restart_on_activate: no
17:28:43.278: close_when_inactive: no
17:28:43.278: full_decode: no
17:28:43.278: ffmpeg_options:
17:28:43.296: [Media Source 'cam 2']: settings:
17:28:43.296: input: rtsp://192.168.1.18
17:28:43.296: input_format:
17:28:43.296: speed: 100
17:28:43.296: is_looping: no
17:28:43.296: is_linear_alpha: no
17:28:43.296: is_hw_decoding: no
17:28:43.296: is_clear_on_media_end: yes
17:28:43.296: restart_on_activate: yes
17:28:43.296: close_when_inactive: no
17:28:43.296: full_decode: no
17:28:43.296: ffmpeg_options:
17:28:43.307: Switched to scene 'Scene'
17:28:43.307: ------------------------------------------------
17:28:43.307: Loaded scenes:
17:28:43.307: - scene 'Scene':
17:28:43.307: - source: 'cam' (ffmpeg_source)
17:28:43.307: - monitoring: monitor and output
17:28:43.307: - source: 'cam 2' (ffmpeg_source)
17:28:43.307: - source: 'Mic/Aux' (wasapi_input_capture)
17:28:43.337: WASAPI: Device 'Microphone Array (Intel® Smart Sound Technology for Digital Microphones)' [48000 Hz] initialized (source: Mic/Aux)
17:28:43.369: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Mic/Aux)
17:28:43.369:
17:28:55.778: User Removed source 'Mic/Aux' (wasapi_input_capture) from scene 'Scene'
17:29:19.109: User changed audio monitoring for source 'cam' to: none
17:29:21.882: User changed audio monitoring for source 'cam 2' to: none
17:29:26.577: User changed audio monitoring for source 'Desktop Audio 2' to: monitor only
17:29:58.146: User added source 'Mic/Aux' (wasapi_input_capture) to scene 'Scene'
17:32:20.160: [win-wasapi: 'Mic/Aux'] update settings:
17:32:20.160: device id: default
17:32:20.160: use device timing: 0
17:32:30.944: [win-wasapi: 'Audio Input Capture'] update settings:
17:32:30.944: device id: default
17:32:30.944: use device timing: 0
17:32:30.951: User added source 'Audio Input Capture' (wasapi_input_capture) to scene 'Scene'
17:32:30.959: WASAPI: Device 'Microphone Array (Intel® Smart Sound Technology for Digital Microphones)' [48000 Hz] initialized (source: Audio Input Capture)
17:32:36.912: [win-wasapi: 'Audio Input Capture'] update settings:
17:32:36.912: device id: default
17:32:36.912: use device timing: 0
17:33:01.604: User Removed source 'Audio Input Capture' (wasapi_input_capture) from scene 'Scene'
17:33:01.633: WASAPI: Device 'Microphone Array (Intel® Smart Sound Technology for Digital Microphones)' Terminated
17:33:09.555: [win-wasapi: 'Audio Input Capture'] update settings:
17:33:09.555: device id: default
17:33:09.555: use device timing: 0
17:33:09.560: User added source 'Audio Input Capture' (wasapi_input_capture) to scene 'Scene'
17:33:09.573: WASAPI: Device 'Microphone Array (Intel® Smart Sound Technology for Digital Microphones)' [48000 Hz] initialized (source: Audio Input Capture)
17:33:14.457: [win-wasapi: 'Audio Input Capture'] update settings:
17:33:14.457: device id: default
17:33:14.457: use device timing: 0
17:35:45.187: [win-wasapi: 'Audio Input Capture'] update settings:
17:35:45.187: device id: default
17:35:45.187: use device timing: 0
17:35:50.878: User Removed source 'Audio Input Capture' (wasapi_input_capture) from scene 'Scene'
17:35:50.902: WASAPI: Device 'Microphone Array (Intel® Smart Sound Technology for Digital Microphones)' Terminated
17:36:05.222: User Removed source 'Mic/Aux' (wasapi_input_capture) from scene 'Scene'
17:38:42.888: ==== Shutting down ==================================================
17:38:42.898: WASAPI: Device 'Headphones (Realtek(R) Audio)' Terminated
17:38:42.901: WASAPI: Device 'Headphones (Realtek(R) Audio)' Terminated
17:38:42.903: WASAPI: Device 'Microphone Array (Intel® Smart Sound Technology for Digital Microphones)' Terminated
17:38:43.006: All scene data cleared
17:38:43.006: ------------------------------------------------
17:38:43.006: [obs-ndi] preview_output_deinit()
17:38:43.006: [obs-ndi] +ndi_output_destroy('OBS Preview'...)
17:38:43.006: [obs-ndi] -ndi_output_destroy('OBS Preview'...)
17:38:43.116: [obs-websocket] [obs_module_unload] Shutting down...
17:38:43.116: Tried to call obs_frontend_remove_event_callback with no callbacks!
17:38:43.116: [obs-websocket] [obs_module_unload] Finished shutting down.
17:38:43.118: [obs-ptz] plugin unloaded
17:38:43.118: [obs-ndi] +obs_module_unload()
17:38:43.118: [obs-ndi] obs_module_unload: goodbye !
17:38:43.118: [obs-ndi] -obs_module_unload()
17:38:43.119: [Scripting] Total detached callbacks: 0
17:38:43.119: Freeing OBS context data
17:38:43.149: == Profiler Results =============================
17:38:43.149: run_program_init: 1072.12 ms
17:38:43.149: ┣OBSApp::AppInit: 11.123 ms
17:38:43.149: ┃ ┗OBSApp::InitLocale: 1.225 ms
17:38:43.149: ┗OBSApp::OBSInit: 1036.02 ms
17:38:43.149: ┣obs_startup: 4.725 ms
17:38:43.149: ┗OBSBasic::OBSInit: 811.968 ms
17:38:43.149: ┣OBSBasic::InitBasicConfig: 0.517 ms
17:38:43.149: ┣OBSBasic::ResetAudio: 0.222 ms
17:38:43.149: ┣OBSBasic::ResetVideo: 108.997 ms
17:38:43.149: ┃ ┗obs_init_graphics: 107.471 ms
17:38:43.149: ┃ ┗shader compilation: 72.671 ms
17:38:43.149: ┣OBSBasic::InitOBSCallbacks: 0.006 ms
17:38:43.149: ┣OBSBasic::InitHotkeys: 0.021 ms
17:38:43.149: ┣obs_load_all_modules2: 299.317 ms
17:38:43.149: ┃ ┣obs_init_module(aja-output-ui.dll): 0.152 ms
17:38:43.149: ┃ ┣obs_init_module(aja.dll): 0.103 ms
17:38:43.149: ┃ ┣obs_init_module(coreaudio-encoder.dll): 0.712 ms
17:38:43.149: ┃ ┣obs_init_module(decklink-captions.dll): 0 ms
17:38:43.149: ┃ ┣obs_init_module(decklink-output-ui.dll): 0 ms
17:38:43.149: ┃ ┣obs_init_module(decklink.dll): 1.094 ms
17:38:43.149: ┃ ┣obs_init_module(frontend-tools.dll): 4.813 ms
17:38:43.149: ┃ ┣obs_init_module(image-source.dll): 0.008 ms
17:38:43.149: ┃ ┣obs_init_module(obs-browser.dll): 0.393 ms
17:38:43.149: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.673 ms
17:38:43.149: ┃ ┃ ┗nvenc_check: 0.174 ms
17:38:43.149: ┃ ┣obs_init_module(obs-filters.dll): 0.662 ms
17:38:43.149: ┃ ┣obs_init_module(obs-ios-camera-source.dll): 0.024 ms
17:38:43.149: ┃ ┣obs_init_module(obs-ndi.dll): 19.513 ms
17:38:43.149: ┃ ┣obs_init_module(obs-outputs.dll): 0.008 ms
17:38:43.149: ┃ ┣obs_init_module(obs-ptz.dll): 62.23 ms
17:38:43.149: ┃ ┣obs_init_module(obs-qsv11.dll): 150.954 ms
17:38:43.149: ┃ ┣obs_init_module(obs-text.dll): 0.188 ms
17:38:43.149: ┃ ┣obs_init_module(obs-transitions.dll): 0.009 ms
17:38:43.149: ┃ ┣obs_init_module(obs-vst.dll): 0.004 ms
17:38:43.149: ┃ ┣obs_init_module(obs-webrtc.dll): 0.006 ms
17:38:43.149: ┃ ┣obs_init_module(obs-websocket.dll): 6.73 ms
17:38:43.149: ┃ ┣obs_init_module(obs-x264.dll): 0.001 ms
17:38:43.149: ┃ ┣obs_init_module(rtmp-services.dll): 0.961 ms
17:38:43.149: ┃ ┣obs_init_module(text-freetype2.dll): 0.082 ms
17:38:43.149: ┃ ┣obs_init_module(vlc-video.dll): 0.038 ms
17:38:43.149: ┃ ┣obs_init_module(win-capture.dll): 1.961 ms
17:38:43.149: ┃ ┣obs_init_module(win-dshow.dll): 2.327 ms
17:38:43.149: ┃ ┣obs_init_module(win-wasapi.dll): 0.011 ms
17:38:43.149: ┃ ┗reset_win32_symbol_paths: 0.194 ms
17:38:43.149: ┣OBSBasic::InitService: 1.425 ms
17:38:43.149: ┣OBSBasic::ResetOutputs: 0.238 ms
17:38:43.149: ┣OBSBasic::CreateHotkeys: 0.035 ms
17:38:43.149: ┣OBSBasic::InitPrimitives: 0.079 ms
17:38:43.149: ┗OBSBasic::Load: 282.314 ms
17:38:43.149: obs_hotkey_thread(25 ms): min=0.003 ms, median=0.014 ms, max=1.2 ms, 99th percentile=0.334 ms, 100% below 25 ms
17:38:43.149: audio_thread(Audio): min=0.004 ms, median=0.07 ms, max=4.195 ms, 99th percentile=0.897 ms
17:38:43.149: obs_graphics_thread(33.3333 ms): min=0.098 ms, median=1.832 ms, max=27.718 ms, 99th percentile=3.271 ms, 100% below 33.333 ms
17:38:43.149: ┣tick_sources: min=0.001 ms, median=0.012 ms, max=26.165 ms, 99th percentile=0.052 ms
17:38:43.149: ┣output_frame: min=0.09 ms, median=1.355 ms, max=12.321 ms, 99th percentile=2.627 ms
17:38:43.149: ┃ ┗gs_context(video->graphics): min=0.09 ms, median=1.355 ms, max=12.311 ms, 99th percentile=2.625 ms
17:38:43.149: ┃ ┣render_video: min=0.013 ms, median=1.218 ms, max=10.403 ms, 99th percentile=2.454 ms
17:38:43.149: ┃ ┃ ┗render_main_texture: min=0.007 ms, median=1.209 ms, max=10.368 ms, 99th percentile=2.437 ms
17:38:43.149: ┃ ┗gs_flush: min=0.036 ms, median=0.134 ms, max=3.492 ms, 99th percentile=0.313 ms
17:38:43.149: ┗render_displays: min=0 ms, median=0.389 ms, max=11.157 ms, 99th percentile=1.082 ms
17:38:43.149: =================================================
17:38:43.149: == Profiler Time Between Calls ==================
17:38:43.149: obs_hotkey_thread(25 ms): min=24.349 ms, median=25.515 ms, max=30.334 ms, 48.7422% within ±2% of 25 ms (0.00849834% lower, 51.2493% higher)
17:38:43.149: obs_graphics_thread(33.3333 ms): min=30.772 ms, median=33.333 ms, max=35.898 ms, 99.789% within ±2% of 33.333 ms (0.105497% lower, 0.105497% higher)
17:38:43.367: Number of memory leaks: 0
