Sound routing question about simultaneously sending audio to monitor out and VB-Audio Virtual Cable (i.e. local audio and Zoom)
yonkiman
I'm doing hybrid presentations, where half the audience is live in the room with me and all this hardware, and half is on Zoom. I've almost got it all working, but I can't figure out this last problem.
I need to send OBS Studio's output to our local sound system (and a projector for the video) and also send it to Zoom (both audio and video). The video's easy thanks to OBS's Virtual Camera. The audio is a lot harder. Looking around the web and forums, it seems like the VB-Audio Virtual Cable plugin should be all I need to make this happen, so I'm trying that.
The problem is that if I set the monitoring device (File/Settings/Audio/Advanced/Monitoring Device) to use the virtual cable, there's no audio out for our sound system.
And of course if I set the monitoring device to be the sound card in my PC, there's no audio to Zoom.
But then I discovered that if I enable Track 1 in the Advanced Audio Properties for the source, I will get the other audio output I need. However over time (or at least over switching scenes) this sound falls out of sync with the video to the point where it's unacceptable.
So my questions are:
  1. What am I doing wrong?
  2. Is there a better way to accomplish this?
  3. How do the "tracks" work? Why does selecting Track 1 magically send the audio to the device I need? Is that assigned somewhere?
Any tips/suggestions much appreciated.
yonkiman
Found a solution that seems to work well: VirtualAudioStream. $29 USD. OBS monitor output goes to "Stream 1", route Stream 1 to my local audio device for monitoring/sending to local PA system, and set the Zoom Microphone input to "Stream 1" to send the audio to Zoom. Seems to be working great, no latency that I can detect.
cyclemat
voiuce meter can it to !
and windows can send audio from progamms direct to sound hardware and software !
