Hello ! I have a problem with my OBS ... Sound is not stable ....
When i put an audio source ( Asio, source media....)
First the meter is visible then it disappears ( look at screens shots...)
Any ideas ?
Thanks you for your help !
Mathieu
10:17:40.569: asio-input: listener for device 1 created: source: d21ffd90
10:17:46.585: asio-input: The driver could not be initialized
10:17:46.585:
10:17:46.585: asio-input: The device has already been initialized
10:17:46.585:
10:17:46.585: asio-input: Device loaded does not support 44100 Hz sample rate
10:17:46.585:
Problem is fixed... "The audio mixer for the source "Kriis" will not be visible until the Scene is Transitioned to the Program window" that's true....
and that's not reassuring in preview mode.
It is difficult to tell you why this is happening. You can try resetting the settings again. Audio Device is set to Monitor in Settings> Advanced> Audio Monitoring, and what sources (if any) are set for Monitor or Only Output and Edit in Monitor> Advanced Audio Properties.
