Question / Help sound and connection
N84Jrnation
Hi i and new and running into a couple speed bumps. first on is there is no sound when i have a video playing on OBS. Secondlydoes anyone know how to connect OBS to Vaughn Live. when i load the stream code it says it cant connect. is there a special url i need. any helps is appreciated
EBrito
OBS has no sound monitoring yet.
https://vaughnlive.tv/howto/xsplit
I think this is what you need to do.
I hope this helps
N84Jrnation
yes that did smooth out thank you. would you by chance know how to use webcammax as a virtual camera so i could stream how to videos i have recorded on my pc.
EBrito
Stream videos recorded:
Use media source or VLC source
Webcammax: I haven´t used it.
But I think it will create a virtual webcam that can be used as a source (Same as manycam, for instance)
N84Jrnation
EBrito is there a way to make a video player available in the sources for a scene. like why wont OBS recognize my video player. if i use media sorce i have to load individual movies, cant do a playlist
