Thaumaturge
Greetings!
I'm attempting to record some gameplay (offline; not streaming) using OBS Multiplatform, but am finding that recording produces a significant drop in frame-rate--from above sixty to just above twenty. This seems to result from simply running OBS; actually recording produces only a slight additional drop in frame-rate.
I've already performed several searches and messed around with various settings, to little avail. It probably doesn't help that I'm not terribly familiar with video, audio, and recording matters, so I may well have missed or mis-applied the advice most relevant to my situation.
I have already disabled the preview, which helped somewhat (I was previously seeing frame-rates of around seventeen or eighteen, as I recall).
Another screen recorder (LoiLo) managed to produce a recording at thirty frames per second with the same game, so the process would seem to be theoretically possible on this machine. (I mainly chose against that recorder because it doesn't seem to be willing to record the cursor.)
My system specs:
Dell Inspiron 15 3000 Series
CPU: Intel Core i7-5500U @2.40GHz (4 CPUs)
Memory: 8GB
GPU: NVidia GeForce 840M (2GB, I think)
(It does appear that there is also an integrated Intel GPU present. As I gather that OBS makes use of the GPU, I tried to have the NVidia Control Panel specify that OBS use the NVidia card, but my settings there don't seem to remain in effect. :/)
My log file should be available here:
https://gist.github.com/52436bf390d38514d93a
(Given a previous log, the Log Analyser only reported that my CPU Usage Preset was set too low. (It's currently on "ultrafast".))
My thanks for any help given!
My system specs:
Memory: 8GB
