Signal Culture Input Amplifier problems loading OBS Virtual Camera, Win 11?
bravedog
I recently discovered the very interesting Signal Culture apps, and for now have only installed the free Input Amplifier, which inputs 4 signals from live or saved files, but am having major problems including damaging crashes.
Processor AMD Ryzen 9 3950X 16-Core Processor, 3500 Mhz, 16 Core(s), 32 Logical Processor(s)
Win11
NVidiaX505BV-FMQR
Focusrite Scarlett 18i8 3rd Gen
I'm unable to open OBS in Input Amp, though it has a Virtual Camera option and is supposed to be able to load OBS; I've installed NDI Runtime 6 and Spout successfully in OBS, but running Virtual Camera in OBS, which does work with other devices, just shows black screen 320x400 when Virtual Camera is chosen in Input Amp - this is the same odd result as with my StarTech though without the Win11 crashes [see below] so may be related. I've also tried putting a Dedicated NDI Output on an OBS stream both paired with Virtual Camera on and not, which changes nothing. Apparently many people can indeed use Virtual Camera and Dedicated NDI Output to open OBS in Input Amp, I've followed many google suggestions which seemingly should work. Advice on getting OBS into Input Amp? thx
Not OBS but may be rellated to those issues: I teated Input Amp 1.1 to see if it accepts the signal from my StarTeach SVID2USB232 video capture device which routes audio, SVIDEO ,and composite video to my computer and works well in OBS. Input Amp detects the capture device identified same as in OBS and other apps as USB 2828x Video, but - no video appears, and it shows in Input Amp as a black screen at 320x440 which is wildly off. There's 7 submenu resolutions, none of which is 320x440, I tried all and none do anything, including that for all it stays saying 320x440 in the channel window.
I do get a webcam image so tried changing the res in its dropdown. This caused a major crash of Win11 causing various problems after restart, including further crashes of Win11 when trying to load the StarTech in OBS and need to reinstall Chrome, but which seem to have been addressed by restoring Windows to an earlier state and reinstalling a few things.
One possibility is acquiring another analog SVHS to USB converter known to work in Win 11 with Input Amp,preferably inexpensive; but the similar problems with OBS Virtual camera suggest there's some different config issue. Maybe just having it in Input Amp's dropdown list is messing with my system and also interfering with Virtual camera? Though it seemingly shouldn't.
[Also the close>X in Input Amp window is greyed out and it can't be closed even by clicking its Close Window in the Taskbar; the only way I've found to close it is to open Task Manager and end the process. Is there a simpler way?]
Windows then crashed again from Input Amp without the capture device chosen, again from the webcam seemingly at default this time when chosen, though restarting now it seems stable with webcam input working? - Also, just looking at the StarTech cap options in Input Amp to write down the details without even loading it into Input Amp somehow changes its device settings so it no longer can be seen in any app on my cvomputer; had to fix only by restoring Win11 to an earlier time again, So maybe all this is connected to the OBS issue.
ps Jason of SC seems very helpful but w holidays and an upcoming tour can't help much now. He suggested looking at a possible antivirus conflict but stopping AVC changed nothing.
log file:
https://obsproject.com/logs/vi3Xzb97LRY7Fo4Q
